SOURCE: Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
SOURCE: How can you buy and
You will find the correct battery at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
SOURCE: Remington R-1000 battery replacement
I guess by now you have either thrown out the shaver or found out how to take the cover off.
The secret is to remove the bottom cover plate (Cap) as described in the manual. There is a small slot at the back of the charging cord recess (see photo) that allows you to pop it off with a small, flat blade screwdriver. There are 2 screws under the cap, and 2 more at the top under the trimmer assembly, which is removed as described in the manual (the manual states there are only 3 screws holding the cover).
The batteries are AA NiMH, 1800 mAh capacity, which I hope to get at The Source (used to be Radio Shack in Canada).
When removing the batteries, make sure to carefully pry off the heat sensor which is attached to one battery with a dab of silicone (and which must be reattached later).
I have attached a few photos to show the slot in the cap, and the battery wire colours when you are reconnecting new batteries.
MikeD
SOURCE: Can batteries in Remington 5130
Yes you can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
