Question about ViewSonic Optiquest Q19wb LCD Monitor
My Viewsonic Optiquest Q19 monitor blanks out although the light stays green. If I turn it off and on again, I can see for a few seconds (sometimes for longer) but then it blanks again
  • 788 Answers
Sorry about your problems with the View Sonic 19” Monitor.
1st. thing you have to decide is weather the unit is worth repair and if you have the technical background to complete the repair.!!
If the power Led stay’s on and the video blanks out, it is most likely the backlight tube.
2nd. You can tell for sure, if you use a strong flashlight and see data on the screen.
If you can see data or images, it is the backlight. If the inverter board was bad, it would shut the power circuit down and you would not have continues power from the supply.
3rd. The backlight is not an easy job to undertake. Again, if you have little or NO technical background, you may want to pass on this project.
4th. If you decide to take on this project, you will need to order the backlight and if you are replacing that, you might as well check the Caps. And other components in the power supply and inverter board.
5ft. The backlight tube is cheep and can be purchased locally for under $10.00 USD
I needed to order a 15.1/4” tube for a laptop and decided saving 2 or 3 bucks was worth the investment. However, I ordered from China and had my tubes held up for over 5 working days and could have walked to the manf. And back by the time I had recvd. them.
Decide weather you want to repair it yourself, or have it serviced. A 19” View Sonic can be purchased for under $100.00 New with High Def.
The in shop repair with have to be more than the unit is worth.
Hope this information has been of some help.
If you decide to take on the job, drop me an email and I will go into better detail on what and how to do.
John Ray
john@johnrraycomputer.com
Readers, Please rate our information, it takes time to write this stuff and even if you disagree, that’s better than nothing at all.
Enjoy, and be safe.!.
Try it, it just may work…!!
Posted on Jun 29, 2009
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
2 Suggested Answers
  • 340 Answers
SOURCE: Viewsonic Optiquest Q19 blanks out - just a year old
sounds like the inverter / but you can check the caps on the power supply to see if you are loosing one / could cause the same problem
Posted on Feb 25, 2010
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Optiquest Q19 monitor adjustment off
Finally found out that the Optquest monitor is an viewsonic brand monitor and finally downloaded the manual.
Jan 10, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic Optiquest Q19wb LCD Monitor Logo
846 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
