Question about Husqvarna Chain Saw 20" Bar
Husqavarna chain saw cover
I am having trouble putting the cover back on
  • Dwain Pippen May 11, 2010
    Are you refering to the cover over the chain and bar?
  • 10,865 Answers
Make sure the air filter is properly installed if it is the top cover.
make sure the chain is properly installed if it is the side cover. also make sure the chain is not too tight, as they could put the bar at the wrong angle
Posted on Jun 29, 2009
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
I have a replacement chain for a electric 40cm Bosch chain saw but it can't get the new one on as the chain tensioner will not go back far enough does it ever get blocked and should I take the cover off...
Take the cover off, Take the bar off. Clean it out. Put the chain around the sprocket. Put the bar on. Put the chain around the bar. Tighten the chain a bit. Put the cover on. Tighten the chain.
Feb 22, 2015 | Bosch Saw Chain for AKE 40 / 40-17 / 40-18...
Have a 137e husqavarna saw put new carb on and just fires and dies. Any help would be appreciated
Try when idle to adjust the carb settings.There has to be 2 screws to adjust the low and high.The low is for when the saw is in low at speed or when is not in use for cut.When you pull the handle to start cut then the adjust the high one at max speed.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I was using the saw as a chain saw last weekend to cut up an old tree stump when the chain came off. I don't know how to access it to put it back on and don't have a user manual. The saw belonged to my...
You will have to remove the cover on the side the chain bar goes into. There should be one or two nuts holding the cover on the side. The is also a chain tension adjuster you may have to loosen to put it back on. Make note of the direction of the teeth on the chain. It is an directional chain. The tension adjuster is usually a flat head screw on the front side right beside the chain bar.
Unless it is a really old saw, manuals are available from most manufacturers for free download. See if you can locate a brand name and model number.
Jun 16, 2010 | Remington Electric Pole Saw
Trouble putting clutch cover back on the 350 model husqvarna
Make sure you have the chain brake lever pulled back, if it is in the forward position you will not be able to install the clutch cover.
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cover that holds downthe bar,over flywheel and tightens the
Remove the cover, bar and chain and clean averything. Check the brake band to make sure it isn't broken. Put everything back together and check again. It sounds like worse case it is a worn sprocket or bar.
May 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to install a new tension screw on a husqavarna 365
I have never done this but with the IPL as a guide it looks pretty simple.
Use care; it is easy to trigger the chain brake and is most difficult to reset with the cover off the saw.
Remove the clutch cover (brake off)
Husqvarna 365 IPL example (may not be your saw)
http://weborder.husqvarna.com/order_static/doc/usa/1999/I99000/I9901064.PDF
Detail A (clutch cover)
remove 2 each - 503 21 28-10* screws
remove 537 01 68-01, all parts now accessible.
Find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
GL
Lou
Nov 25, 2009 | Husqvarna Chain Saw 20" Bar
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Husqvarna Chain Saw 20" Bar Logo
116 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
