Question about Whirlpool SF325 Gas Kitchen Range
Oven light won't shut off
My husband took off the oven door my mistake. We finally got it back on now the light won't shut off when I close the door.
  • sparket99 Jun 29, 2009
    I found the button and tried it but the light is still on
  • Mike Price
    Mike Price May 11, 2010
    Hi, There is a button on the front lip of the oven that the door strikes when closing...when pressed the oven light shuts off...press this botton...does the light shut off?
    President:
  • 744 Answers
Ok we must have broken the button when the door was being put back on...this can be checked with a multi meter...check it for condinuity when the button is pressed if you have condinuity the botton is bad...replace it...if you don't have a multi meter you can take terminals off switch..wrap them with electrical tape and power the oven back on..if light goes out it's the switch...you can also just change the switch..they are inexpencive.
feel free to comment again if you have any other questions.
Posted on Jun 29, 2009
  • Mike Price
    Mike Price Jun 29, 2009
    please bare in mind when servicing an appliance you need to disconect the pawer before working on it :)
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Whirlpool interior light won't shut off
That is a really good question....what category did you post it under?
May 28, 2012 | Cars & Trucks
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
We have GE oven. We never used the self cleaning mechanism, but the designation "door locked" is flashing and we can't complete shut the oven door because the latch is not set properly. How can we reset...
MINE DID THIS TONIGHT. I HIT THE CLEAN OVEN BUTTON AND THE DOOR LOCKED STAYED LIT. AFTER ABOUT 1 MINUTE I HIT THE CANCEL BUTTON AND THE LIGHT FINALLY WENT OUT AND I COULD SHUT THE DOOR. HAVE NOT TRIED TO COOK WITH IT YET SO DON'T KNOW IF THE PROBLEM IS SOLVED BUT THE LIGHT DID GO OUT AND I COULD FINALLY CLOSE THE DOOR.
May 14, 2009 | Kitchen Ranges
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Using the self cleaning for the oven
look for the door/ light switch (the door would normally have this pushed in),and press and hold it in, tricking the unit into thinking the door is actually closed. press the clean button then, see what happens. it should try to close itself entirely and then press the cancel button, it should return to normal resting position
Mar 10, 2008 | Ovens
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Whirlpool SF325 Gas Kitchen Range Logo
124 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
