Question about Frigidaire FRT18KG3CW Top Freezer Refrigerator
Frost build up, Frigidaire FRT18K63CW top
I'm having alot of frost in the top freezer, which I'm thinking makes the bottom not to get as cold I see NO red glow in the vent, which now have ice covering them., I'm thinking the defrost heater is not working. Can this heater be replaced, and is this something I can fix, by taking the panel off from inside the freezer also how much would this part cost
  • 82 Answers
The heater can be replaced $30-$40 appliance parts store. Make sure that's the part you need most places won't return electrical parts. Could be a defrost terminator also.
Posted on Jun 29, 2009
Top freezer works but bottom refrigerator warm
Good Morning friend, thanks for your inquiry!
From the information you have provided the freezer on your Frigidaire refrigerator is working and the bottom portion is not. This sounds like a potential issue with your damper or defrost timer. You should check the damper and that is located on the rear upper wall. If the damper is not working properly it could be due to frost build-up or food blockage. I would recommend checking the freezer to make sure there is no frost build-up or food blocking the damper on the rear wall. I hope this information is helpful to some degree. -Matt
Feb 10, 2015 | Frigidaire Refrigerators
I have a Hotpoint hss251fmd and the freezer and refrigerator are getting warm at the top. the bottom and the back are cold. The freezer Is cold but not freezing everything. There's alot of frost inside...
Sounds like defrost cycle has been altered. Look into back of freezer and see if a layer of frost is building. If yes then unplug and place items from freezer into an ice chest or another freezer. Remove the panel that showed the frost layer and defrost the evaporator coils with a hair drier Examine the WR51X10055 Defrost Heater and test if you cannot see burn marks HERE It does not hurt to also change the WR50X10068 Defrost Thermostat Instructions on replacing the defrost thermostat are also on the same page. Here is a=> Service Manual
I will be here to answer any questions, Thanks Sea Breeze
May 08, 2012 | GE Refrigerators
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Amana refrigarator
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Also check and make sure your compressor is running. Compressor failure is common on this make refrigerator. Visit me on Ebay username: themackshack. Good luck! Mack
Dec 15, 2007 | Amana ABB1921DE Bottom Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Frigidaire FRT18KG3CW Top Freezer Refrigerator Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
