Question about Toshiba Satellite 1415-S105 Notebook
Won't power up and is plugged into wall outlet
  • 30 Answers
You need a new computer battery.
Posted on Jun 29, 2009
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Rca phd 50500
If no power, check your power plugs and wall outlet if its working. If not might have to open it, and check fuse and Power Supply Unit. Revert if anything.
Dec 28, 2011 | RCA Televison & Video
Printer wont switch on
Try to plug the printer into a different known working power outlet in the wall. Bypass any power surge devices or power strips - these tend to draw away power from the printer.
Dec 28, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
Plugged it in to a wall outlet, turned on the computer, the microsoft screen scene appeared, the jingle played, then it turned itself off and won't turn back on.
Unassemble the battery and after 5 minutes reassemble it, then plug it in another wall outlet and when the charging light turn on, turn on the notebook.
Jul 21, 2011 | Dell Lattitude D610
Power to switch, will not come on, is there a reset button?
Try to unplug the power adapter from the printer. Disconnect the power cord from the power outlet in the wall.
Wait at least 10 seconds before you re-plug the power cord into the power outlet (bypass any power strips or surge devices). Re-plug the power adapter into the printer. If printer won't automatically power on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 27, 2011 | Lexmark X75 All-In-One InkJet Printer
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Toshiba Satellite 1415-S105 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
