Question about Car Audio & Video
Found the code for my 2005 Dodge Sprinter radio, BUT have no instructions on how to get the radio to accept it-- HELP would be much appreciated.
  • 1 more comment
  • judydownsout Jul 04, 2009
    From judydownsouth--Thank you for replying. Yes, I am from US. Code is 5 digits. I punch a button on radio; a digital screen indicator goes to 1st position & I then turn knob to enter digit (1 thru 9). I punch button again to go to 2nd position & turn knob to select 2nd digit AND so on. I can enter the 5-digit code, BUT I cannot get the radio to accept or confirm it. I do not have a manual for the radio--bought van 2nd-hand. So very different from UK, I don't know if systems even come close to each other.
  • colin butcher May 11, 2010
    I need you to explain further, how many digits is your code? I am assuming your from America? by the make of vehicle, Here in England UK we have a 4 digit code system so what ever the code is we would press 1 ex amount of times 2 ex amount of times 3 ex amount of times and 4 ex amount of times and then 5 to confirm, so if you code is only 3 digits long then try button 4 to confirm code, I hope you understand this, good luck mate,Colin.
  • yadayada
    yadayada May 11, 2010
    contact the dealer.
  • 512 Answers
SOURCE: 2005 dodge sprinter
2359 is for high or low boost....more than likely it is the turbo resonator or the charge air hose to the intake has a split in it
Posted on Oct 15, 2008
  • 512 Answers
SOURCE: UNLOCK RADIO CODE DODGE SPRINTER
give me the vin and i can get you the code if it is the original radio
Posted on Feb 04, 2009
  • 1596 Answers
SOURCE: 2005 Dodge 1500 code p0404 EGR valve.
The electronic EGR valve and solenoid assembly is attached to the rear of the left cylinder head ,
  1. Remove electrical connector (5) at top of EGR valve solenoid.
  2. Remove tube mounting bolt (1) at intake manifold.
  1. Remove two bolts (4) connecting EGR tube (1) to valve assembly.
  2. Remove gasket located between EGR tube flange and EGR valve assembly.
  3. Remove two EGR valve mounting bolts (5).
  4. Separate valve assembly (3) from engine.
  5. Remove and discard metal gasket located between cylinder head and valve assembly.
INSTALLATION
  1. Clean area at rear of left cylinder head where it joins base of EGR valve.
  2. Clean EGR tube where it joins EGR valve.
  3. Position new gasket between EGR valve and cylinder head.
  4. Position EGR valve to cylinder head. Install and tighten two bolts (5). Refer to Torque Specifications.
  5. Position new gasket between EGR tube flange and EGR valve assembly.
  6. Position EGR tube (1) to side of EGR valve and into intake manifold.
    1. Install EGR tube flange bolt (1) at intake manifold. Tighten bolt. Refer to Torque Specifications.
    2. Connect electrical connector (5) to top of EGR valve solenoid (2).Do a final tightening of two EGR tube bolts (4). Refer to Torque Specifications
Posted on Feb 05, 2009
  • 4944 Answers
SOURCE: laguna blaupunkt radio locked
To unlock it , leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
It could be up to 24 hours...but normally only an hour or two.
Posted on Sep 06, 2009
  • 55 Answers
SOURCE: 2006 dodge sprinter esp light on and tire spin light
Go to nearest garage and do diagnosis test and fault erase.
Posted on Oct 07, 2009
I need the radio code for mercedes sprinter modell 2006
I need radio code for Mercedes sprinter 2004 plis help me
Nov 04, 2010 | 2006 Dodge Sprinter
I have a 2005 Dodge Sprinter 2500. Battery exploded when I turned the ignition on. New Battery got installed but when I turned on the radio a signal appeared CODE. What does this mean?
any time the battery is removed without a memory saver the radio gets locked-this is for security purposes-if you bought the vehicle brand new there should be a radio code card in with your owners manual-if not you will have to contact a dodge dealer to get the new radio code or to get it reset-if you have to go to dodge for the code i recommend writing it down in case it happens again
Sep 15, 2010 | 2005 Dodge Sprinter 3500 Standard Roof
I have a 2005 dodge sprinter. i just changed the intake house and found oil in it. is this normal? i also have PO299 reading on my obdII tool.
Normal to have oil in hoses, Not sure what that code is? Some scan tool codes don't correspond with the factory codes. Do you have a manual for the scan tool? it should tell you what it is, otherwise it doesn't mean anything
Aug 04, 2010 | Dodge Sprinter
Radio unlock code dodge sprinter
Post the VIN number and I may be able to help
Jul 23, 2010 | 2005 Dodge Sprinter 3500 Standard Roof
I put a new battery in the sprinter and new a need a radio code. (2005 year model) has a radio called ,"sound 30".
if its a factory radio, the code is based on your VIN, you'll have to phone the dealership. There is supposed to be a card in your glove box that says the code but it's usually not there...
Mar 30, 2010 | 2004 Dodge Sprinter
Radio will not turn on
if you have correct code from dealer you should be coming right. Try again
Mar 28, 2009 | 2006 Dodge Sprinter
the dealer shouldnt have to hand out radio codes to anyone. the dealer will need to see your licence and registration document to prove that you are the owner of the vehicle.
Jan 29, 2009 | 2004 Dodge Sprinter
2005 sprinter dome and cargo lamps inside don't work, radio also quit working
there is a fuse in the panel on the bottom side of the steering column...if i rmember right it is fuse 8
Jul 02, 2008 | 2004 Dodge Sprinter
Car Audio & Video Logo
578 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
