Question about Fuji FinePix S1000FD Digital Camera
Read/write error keeps coming up on fuji finepix S1500
Sorry, i just sent in my question regarding a brand new fuji finepix that keeps saying read error/write error for 50% of the photos we try to take on it. not sure if we are doing something wrong.
but the camera i am asking about is in fact and S1500 not the S1000.
don't know if it make any difference but thought i should amend it.
thanks,
Maryrose Crook.
SOURCE: Fuji FinePix 3800 Initialization glitch
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Posted on Dec 31, 2007
Orbixx
  • 133 Answers
Yes, you'll need to format the xD Picture Card. You may be able to do this inside the camera in the options, if not - you'll need to connect it to your computer to get it to appear as a drive letter in "My Computer". Select the new drive in My Computer, this will be your card, right click it and click Format, then proceed to format it. This should sort your problem out.
Posted on Sep 07, 2007
craxtech
  • 33 Answers
SOURCE: My computer won't recognize my Fugifilm Finepix s1500
try installing the drivers from the fujitsu website
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=878899
if you already tried it w/ different computers & still it wont work, the device itself is already busted
Posted on Jul 25, 2009
BillB-SA
  • 2761 Answers
SOURCE: fuji finepix s1000 zoom error lens is stuck out what can I do???
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
Posted on Sep 10, 2009
SOURCE: Fuji finepix s1500 won't turn on
same problem with mine...
Posted on Dec 26, 2009
I have a FinePix A900 camera with a 1 GB SD card. I connected a cable in the A/V Out to watch the photos on a TV set. At this moment something went wrong. The camera LCD becomes black and no picture was...
First of all, it is never advisable to copy a picture from the computer to a memory card or camera. Most of the time, it will corrupt the card and sometimes the camera. Second, the procedure for connection to a tv needs to follow a detailed procedure. This is different for each tv and camera. For example, on my tv, my camera and tv need to be off, I make the connection, turn on the tv, set the tv menu to "photos", turn on the camera, and then follow the on-screen prompts from there. If I change that order, I have problems.
Jun 19, 2011 | Fuji FinePix J10 Digital Camera
Fuji Finepix s1000fd i/o error when loading photos to PC
I had same problem,Vista/Fuji-finepix.
Go to control panel click on Autoplay, camera is under devices probably says " take no action" with red sign.click on the bar and a drop down appears,click on import to windows or ask me first,click save and it should work fine. i uninstalled the fuji software,i assume it has issues with microsoft settings.
Feb 08, 2009 | Fuji FinePix S2000hd Digital Camera
Digital camera reads " read error" when I try and view the pictures
Change your memory card. I had same problem with my new Fuji Finepix S1000fd. Problem always came out in flash mode, with write/read error and freezing problems. Always use Premier brand memory cards. Prior to changing it, I also suggest to format your present card.
Feb 01, 2009 | Fuji FinePix S1000FD Digital Camera
After surfing for solutions, I tried uninstalling all the Fuji software and using Windows to pull the pictures off the camera...It worked! Card and USB were working just fine even though they came back with errors using the Fuji software.
Dec 22, 2008 | Fuji FinePix S1000FD Digital Camera
READ ERROR
the photo was not recognize when you took itthats way it would say read error. no way to retrieve thos pics...sorry..
Feb 24, 2008 | Fuji FinePix A400 Digital Camera
READ ERROR
I would try another card with the camera to see if there is a fault in your camera or the USB cable. If the other card works fine, then there nay be some compatibility issues with the M type XD card in your camera. Just for reference: I have several older FujiFilm digital cameras that I still will not use the newer style cards with. Newer meaning the 'M' and 'H' series cards. Fuji says they will work fine, but I'm always leery of newer techno gear being 100% compatible with older stuff.
Here is a link to Fuji's memory card chart: FujiUSA
Jan 14, 2008 | Fuji FinePix A360 Digital Camera
Write error
Hi, Sounds like a memory problem. You can try using the built-in menu utility function of formatting the memory (be it internal or external memory). Of course this will also delete all current files/photos in it. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 03, 2007 | Fuji FinePix Z1 Digital Camera
Card Error Message keeps coming up
Please repost with the kind of card you are using to help me help you.
Aug 02, 2007 | Fuji FinePix A205 Digital Camera
Fuji FinePix A500 won't take photos
Customer support at www. Fuji. com is the place to go. They are very good and helpful
Dec 25, 2006 | Fuji FinePix A500 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
939 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
