Question about Maytag Atlantis MDE6400AY Electric Dryer
Maytag atlantis MDE6400AYW dryer
My dryer does not start. When  I pull the rotary plug, nothing happends. The interior light comes on. ALL this happened immediately after a thunderstorm.
I was able to open and check the two thermal fuses and the door switch and they are fine.
I do not know how to check the timer. Could be timer be fried? Also, is there a PCB or control board that can be checked?  Is there a test for the motor to make sure it is not fried?
If someone can post a link to the manuals that would be great.
hunter19_46m
  • 7482 Answers
SOURCE: My Maytag atlantis MDE6400AYW runs
Hi sotpaldy...
Here are a few things to check
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on Jun 04, 2011
the dr
  • 447 Answers
SOURCE: MAYTAG DRYER MDE5500AYW
Have you checked the door switch, thermal fuse on the heater housing(this will keep it from starting).
Posted on Oct 06, 2007
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
kachbibi1
  • 979 Answers
SOURCE: maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Posted on Jan 21, 2009
Maytag Atlantis Series MDE6400AYW -- Current is good, brand new power cord, drum light comes on -- When I turn the timer, I can hear it clicking, but nothing else works.
You need a thermal fuse and check the venting heat is backing up causing the fuse to blow fuse part number 307473 located on the back remove back panel to gain access
May 30, 2015 | Maytag Dryers
Trying to hook up three wire plug, witch wires go where? maytag atlantis mde6400ayw
the red and black go to terminals marked L1 and L2 polarity isnt an issue here,and the white or bare is the N terminal or neutral connection,if its non color coded cord as in gray insulated then the 2 outside conductors are the 2 hot wires L1 & L2 and the center is N neutral
Jan 09, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag MDE6400AYW was getting more and more difficult to start. I could pull the knob in different directions to start it, but now it wont start at all. I removed the starter, then the panel, then the...
no way around replacing the timer now. dont think youll get a rebuild diagram on this they come sealed form the factory, problem is they build these cheap a** timers with pull starts in them and they do have a tendency to fail.
Mar 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer won't run
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start, light comes on
hi thanks for the question the thermal fuse fails allot caused by poor venting yo the outside this fuse is located in the front on the air duct thanks the appliance doc
Jul 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Motor is bad= not worth fixing! Sorry, Buy a kenmore or whirlpool- they are good dryers!!!
Dec 12, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
708 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
