Have a Sony KP-51WS510 repairman replaced the three tubes and a couple of boards. He still can't get rid of the red around the outlines of mostly white area's. This also has taken the picture slightly out of focus. this problem is more prevelent in the composite and s-video jacks. thanks Bob
In replacing the CRTs, there are multiple focus adjustments. The basic one first is the Mechanical lens adjustment on the CRTs, (in this case red), the second one is the Electronic Focus on the Screen/Focus Block on the front of the unit behind the front panel. The third focus and on of the most important is the Beam Centering Focus. (In this case RED CTR) It is located on the neck of the CRTs. They are the first set of adjustment rings up from the CRT Boards. If any of these focus adjustments are off they will cause a symptom like yours to occur. Normally these adjustments are made before any convergence adjustments are made. I would double check to see if the repairman made these adjustments.
I hope this helps
Skyassoc
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS...
(More)
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS EXCELLECNTLY NEVER HAD A PROBLEM WITH IT. NOT USED AS MUCH AS A FAMILY ROOM TV, WHICH ARE ON CONTANTLY. WE WERE TOLD THAT THESE WERE NOT OPTIMUM FOR GAMING THAT WAS FINE FOR NOW. WE ARE LOOKING TO REPLACE IT WITH A LCD. WHAT WOULD BE A GOOD SELLING PRICE FOR THIS OLD UNIT.
I own a draper fretsaw Model FS16A stock no 30414. The part is listed on 15ins fretsaw spare parts...
(More)
I own a draper fretsaw Model FS16A stock no 30414. The part is listed on 15ins fretsaw spare parts listing o7/93 key 75A part no. YFS16A stock No 31838 now stock no 24433 plain blade holder No75A also plain-end blades (straight cutting
My 2005 wega projection lcd turns on i can see the show the cable is set to...then a few seconds and...
(More)
My 2005 wega projection lcd turns on i can see the show the cable is set to...then a few seconds and the tv turns off and has a blinking red light that indicates standby mode can this be fixed?
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal...
(More)
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is good except for this red horizontal line running accross the top of the screen. What could be the problem?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
