Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How to replace the SMS fuses on my Mitsubishi ws-65869 tv?
SOURCE:
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Jun 14, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi Bigscreen WS-65869 the power went off
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made later.
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
There are sites on the internet selling a "kit" with the caps etc and instructions for replacing them---if they are bad the silver tops of them will be bulged up and not flat.
Let me know what more information you need--I am here to help.
If this information has helped you rate it as I do this here for free.
SD TECH
Posted on Dec 10, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65869 BLINKING GREEN LIGHT
SD TECH
Posted on May 02, 2010
Slinteriors
  • 8617 Answers
SOURCE: blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Posted on Jul 15, 2010
Mitsubishi WS-65869 TV. I have no power whatsoever
If you do not have the service manual I can get you a link for a free online copy which contains a lot of information for free.
It can be either read or downloaded for free.
May 27, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Not work ws-65869
Jun 13, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
