Question about Dometic Rooftop RV Air Conditioner
Coleman rooftop a/c unit is fried? i plugged my
Coleman rooftop a/c unit is fried? i plugged my camper trailer into a 240volt generator plug, and now the frig, ac, and radio won't work.. help!
  • jj2walsh Jun 30, 2009
    Jeff,
    I have checked the ac control box out and it seemed okay, Its a coleman roof top with wall thermostat, fuse inside t stat was good, i haven't checked for 12v yet...not sure how. the frig is a norcold, I took the cover off the back left sode of the control box, and there was a 3 amp fuse that was okay, but i didn't get the rest of it off, the part with the wires connected to it, i'm guessing there is another fuse in there? anyway thanks for response it was helpful. By the way, I have checked the frig plug for power and the breakers for the ac and frig.
    Thanks, Jeff
    Novelist:
  • 127 Answers
If there Air Conditioner is wall thermostat controlled, then take the front cover off the thermostat and check the fuse. If the fuse is ok, then take the inside cover of the AC down and pull down the control box that is mounted in the intake section of the AC. It is held on with two wing nuts. Remove the cover and observe the relays and the incoming AC wiring. Make sure that none of this is burnt. If all looks ok, turn power on and turn the thermostat to High Cool and check if you can hear the relay click inside the control unit. If not, then check to see if the thermostat has 12V going to it. Start there and see how that goes.
If it is controlled by the ceiling mount t-stat and selector switch. Remove the inner shroud and check the incoming AC wires for OK. If they look ok then check the selector switch and the thermostat.
The Refer has protection from this. Depending on which refer you have (Dometic or Norcold), the process is a tad different. If it is a dometic, go to the outside of the coach and remove the access panel on the rear of the refer. Remove the black cover from the control board (lower left side) and check to make sure that the 120V fuse is good (You will need an ohmmeter to check). If it is fine the check to see if you have power going into the 12V block at the very bottom, rear of the refer. If there is 12V there, then check the plug that the Refer is plugged into for 120V. If none, check the GFCI circuit in either the bathroom of the kitchen. If tripped you will have no power to fridge. Start there and then we will move forward.
Basic same checks for a norcold, board is harder to remove as you have remove wires. Mark and remember where they go.
Hope this helps,
Jeff
Posted on Jun 30, 2009
  • Jeff Myers Jun 30, 2009
    Your Air Conditioner and your refrigerator will not work without 12V. Even though they are 120V Appliances. The AC thermostat and control box are run off of 12V. Pull the front cover off of the tstat and look for the red and white wires. White is ground and red is 12V positive. Check to make sure that you have power there. If so, turn on the tstat to high cool and check for 12V at the control box on the yellow wire, that is the cool feed for the control unit. If all this is ok then I would say that your control box is bad.
    Check the refrigerator for 12V as well. Are the lights on the front of the refer working? What does it do on Gas mode?
    Good luck and keep me informed.
    Jeff
    President:
  • 3,433 Answers
I think you sre screwed. Sorry.
Posted on Jun 29, 2009
Ive got a question about a 22 ft companion travil trailer
Plug it back in to the house electrics .then search for the inverter on the trailer .
Oct 13, 2016 | Coleman 1997 Fleetwood Sunridge Power...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
I'm purchasing a generator to power the Dometic Duo Therm Brisk Air A/C unit in my camper. How many watts does it draw?
You will need at least a 5000 watt generator to run that and a few lights etc... for the camper.
heatman101
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
How do I connect 2 1850 watt coleman generators together to have at least 3500 watts to run my camping trailer?
It wont work. Electricity does not work like that. you can't double the power just by doubling the watts or amps. there is a lot and lots of other things involved.
I would rewire you camper so that half is run be one generator and the other half by the other generator... SO lights and fridge on one and plugs and heater on the other maybe...
Aug 13, 2010 | Electronics - Others
DOES MY COLEMAN ROOTOP HAVE FILTER ON THE OUTSIDE (ROOFTOP)
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Rv electrical question
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Ac wiring problem
as a general rule ,only if your ac was a window unit. aka a 120 volt unit . all other acs use 240 volt. a 120 leg and a 120 2nd leg to equal 240, so there is really no common. what kills acs with a generator is the lack of watts and starting torque. an ac (3 ton) and up needs a generator of 10000 watts minimum to handle starting trque. they also need a hard start kit to boost starting voltage.for god sake someone reply and tell me what a good job i am doing!!!!!!!as in grade the response to your question.
Oct 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
394 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
