Question about SanDisk Sansa e260 MP3 Player
Accidental Rockbox file deletion
I have rockbox on my Sandisk mp3 player. I was deleting music off of my mp3 and i accidentily deleted the rockbox folder. Now i can't even turn on my device without it telling me that the rockbox file cant be found and shutting off
    Sergeant:
  • 268 Answers
You will have to find someone with the same make/model and copy there files over to yours. This sadly is the only way to fix it.
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Posted on Jun 29, 2009
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
How to remove rockbox
plug up to pc/laptop...my computer...open the player and manually delete the rockbox folder...eject from pc safely, shut down and turn it on...rockbox is no longer on the player and will be force to start up original
Aug 03, 2009 | SanDisk Sansa e270 MP3 Player
PROBLEMS DELETING MUSIC FROM MP3 PLAYER
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
I am wanting to delete music
Go to my computer scroll to sansa and open the music folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Reformat Sansa 280
THIS IS HOW TO RESET EVERYTHING ON A E280 SANSA MP3 PLAYER WITH VERSION 1 SOFTWARE
INSTALL RECOVERY TOOL TO YOUR PC
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
NOW HOOK THE SANSA, POWER IT UP HOLDING THE
RECORD BUTTON W/ THE LOCK ON (OR HOWEVER YOU GET INTO THE RECOVERY MODE FOR YOUR UNIT)
CREATE A NEW FOLDER AND CALL IT “ sansa.fmt ” IN THE 16MB FORMAT PARTION FOLDER THAT POPS UP.
REBOOT SANSA.
GO TO SETTINGS AND PLACE IN MSC MODE.
MAKE SURE UNIT HAS THE LATEST FIRMWARE.
-GO TO SANDISK SITE-
( http://www.sandisk.com/driverdownload/download.asp?driverId=7 ) FOR XPSP2+
REBOOT AND IT SHOULD WORK LIKE NEW OR BETTER FOR YOU.
At least this is what i ended up doing to fix mine & it took me a while to figure it all out so i wanted to post it up for you all.
TO ADD DIFFERENT FUNCTIONS BETTER SHUFFLING, EQ, & THEMES CHECK OUT THIS ADD-ON : “Rockbox”
www.rockbox.org
Oct 03, 2008 | SanDisk Sansa E280 MP3 Player
Deleteing music from m240
-Plug your mp3 player into your computer using a usb cord.
-Open My Computer and look for a folder named Sansa"something".
-Open this folder and go into the desired folder[music] where you would want to delete music.
-select a song or multiple songs and press delete.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
Deleteing problems
Go to My Computer>Device Name (m240)>MUSIC Folder, all of the contents are there,
If you do not see a MUSIC folder, you will need to enable hidden files and folders on your computer.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | SanDisk Sansa m240 MP3 Player
Rockbox
1 - since you really did nt delete all of rockbox (you shoud reinstall the whole thing) this will take of the system looking for it.
2 - you will have a dual boot up and a choice of which one u wish
Key Action
Power Start Rockbox
Long Power Shutdown Rockbox
On shutdown, Rockbox automatically saves its settings.
Rockbox has a dual-boot feature. To boot into the original firmware, press and hold the Left button while turning on the player.
feel free to rate the help
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
Rock box??
Go to rockbox home site dowload current bulid and read the manual , then re install rockbox and if you don't want to keep rockbox uninstall it , you will find how to do in manual
good luck
Sep 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
