Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television
Problem for Hitachi UltraVision CineForm 55VG825 55 in. HDTV...
Replaced bulb now tv will not come back on and the
By rickseelbind on Jun 29, 2009
replaced bulb now tv will not come back on and the lamp light is blinking
Solution #1
posted on Jun 29, 2009
Not Rated)
Skyassoc
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 90%, 274 votes
Most of the time when I see this is because the Lamp door is not closed tightly. If you have already checked this and if the set worked perfectly before the lamp was replaced then there is a chance you got a defective lamp. On last caution, I would only use a lamp that came with a cage assembly. I do not recommend replacing the lamp it's-self by taking the cage apart. I have seen too many of them be the wrong lamp or the wrong wattage causing melting of the surrounding plastic cabinet. I stick with the Manufactures lamp assy.
Hope this helps,
Skyasoc
Was this helpful?
Yes
No
Solution #2
Not Rated)
palaboy
Rank: Wiz  Televisions & Videos  Expert
Rating: 82%, 1201 votes
then it is not on the bulb anymore, it is on the Horizontal Deflection Circuit Board, find it, have it replaced or repaired. Secondary to that is measure the output voltage of the TV power supply just before it connect to the horizontal output transistor, a good multimeter will do the job
Was this helpful?
Yes
No
Popular Solutions for Hitachi UltraVision CineForm
Questions and Unsolved Problems for Hitachi UltraVision CineForm
Do you recommend Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television?
Answer
Answer
blue area on bottom left of screen. have noticed it sreading in a longer line up as well of blue... (More)
Answer
tv had light streak down middle of screen then power ,temp and lamp lights started flashing 1 at a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
