Question about GE DBSR453EBWW Electric Dryer
Start Switch Broke
Start switch, which is normally turned to the right and toggles back, was inadvertently turned too far. Now the switch rotates and does not start the dryer.
Is there an inexpensive way to repair.
Thanks for your help.
  • 97 Answers
Hello Friend, Its easy to replace the start switch on your dryer. Just remove the four screws at top of control panel. You will need a start tip bit to remove the screws. Once removed just pivot the panel towards front of washer exposing the inner backside of panel. Now you can easily remove the screws that hold on the start switch and replace with new one. Happy to help, Tim. Please rate my help to you. Thanks.
Posted on Jun 29, 2009
  • MrQuickFixit Jun 29, 2009
    The part you need should be inexpensive at an appliance parts dealer. You can do it. It's a quick, easy fix. Tim
I have a Sears Kenmore elite model# 11072942100 that will not always stay running when pushing the start button, however if I hold down the start button and then turn the dial it will eventually stay
Rick,
Good call on the timer switch. If the teeth have worn at the start position, starting would be delayed until the timer is rotated beyond the worn area. The normal operation of the start button is that it should to be pushed in and held for a second, to prevent inadvertent starts.The problem could be related to the door latch. The door safety switch will make intermittent contact if the door is not completely latched. If the door has become misaligned from downward pressure, it may not be drawing the door in enough to push in the switch. First check the alignment of the door. If the door is low, try bending the hinges back up. Open the door just enough to get your fingers inside the bottom of the door and slowly pull up. If the door is better aligned it may push the switch in better. Close the door and try the dryer.Next try holding the door in with one hand and pressing the start button. If the dryer starts every time while pushing the door in, then the latch is worn and should be replaced. I hope this solves the problem.
Good luck
Nov 29, 2014 | Kenmore Dryers
1994 toyata camry the alarm goes off and will not let me start the car.
factory security does not have toggle switches as far as I know so it is probably an aftermarket system. Try one of two things, turn the toggle switch the oposite direction with battery disconnected. Reconnect the battery and try again, the horn will beep a few times when you reconnect. try starting. If that doesn't work, disconnect the battery and turn the key to the on position and reconnect the battery and the horn will sound but will go off get in the car and try to start. It should start and run normally. shut car off, then you should be able to return the toggle switch to the previous position If this happens again turn the toggle switch to the opposite position with the batterry disconnected and turn the key switch to the on position and reconnect the battery and start when started go see a service that installs aftermarket systems and they should be able to reset it security system Hope this helps
Sep 19, 2012 | 1994 Toyota Camry
Lg tv does not turn on
The 55lh90 has a vacation switch on the bottom right corner. It's a toggle switch that interrupts power to the power supply. Should just need to toggle that switch to the "on" position, and everything should be back to normal.
Dec 12, 2011 | LG 55LH90 55 in. LCD HDTV
On & off switch fell off or broke? How can I turn it on if the switch wont fit back in right?
If there are only two wires going to the switch you can unplug the heater and strip about 1/2 inch of insulation off of the wires and twist them together. Use a wire nut or electrical tape to protect connections.
If you can't find the right replacement switch you can use a simple toggle switch in it's place. Or just unplug it when you're done using it. I hope this helps you. Thanks.
Dec 08, 2010 | Comfort Zone CZ-530 Compact Heater
A420n broke the button to turn it on needs replaced
When mine broke all i did was disconnect the two wires from the button, solder to a small toggle switch,drill a hole in the case and fit toggle switch,works fine
Feb 07, 2010 | HP Pavilion a420n PC Desktop
I have a Aries desktop pc that will not start up i have done the fuse in the plug but still nothing is there a fuse in the pc its self and if so where?
Check to see if there is a toggle switch on the back of the case. You may have inadvertently hit the switch and turned it to the off position.
Try moving the switch to the opposite position and then try turning on your system.
If you need further help let me know.
If this solution was helpful please rate it.
Mar 15, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
Powerspec PC 7114, will not powerup by pressing the on button on front of unit?
Do you have a toggle switch on the power supply at the back of the unit? You may have inadvertently turned it off, try toggling it in the other direction.
If that does not work, you may have a dead powersupply or even a dead connection to your on/off button on thee front of the case.
Mar 09, 2009 | Winbook Corporation PowerSpec MCE 410 PC...
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
GE DBSR453EBWW Electric Dryer Logo
113 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
