Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge profile refrigerator does not make ice and I had recently changed the filter
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Did it make ice perfectly fine until the filter change? Did you remember to turn the water back on?
hotuna
  • 288 Answers
SOURCE: GE Regrigerator "Profile" PSS26SHPA SS
It sounds like the drainage for the defrost water is plugged or obstructed somehow. The ice build up is left over water that is freezing due to the fact that it has not been channeled out properly and when the cycle comes back on it freezes.
look for the collection pan underneath the fridge, access the tube ending to there, blow some air through it. Compressed works best if you have access to some. Also I would advise doing this after the unit has been off for a short while, sometimes the plug will be frozen, so give it time to melt just in case. When you blow on the tube there should be no back pressure, this will tell you if the plug has been removed.
Posted on Dec 06, 2007
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
SOURCE: GE Profile refrigerator ice maker stopped working
I have the same issue - call GE, give them your frig model number and they can get you the part nmber of the valve. GE charges about $75 with shipping - you can find it on line for about $45 - I went with GE original parts....it's a pretty easy repiar.
Posted on Jan 02, 2009
706Cajun
  • 34 Answers
SOURCE: Water from Ge profile refrigerator
The water filter for this refrigerator is optional. The GE part number is: WR97X0214, or one of the box stores also carries a universal filter. Just make sure it for a ¼ inch line. The water filter is located on the back side of your refrigerator, and will have to be pulled out from the wall. Use caution not to break the water line when pulling/rolling it out.
Posted on Apr 25, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
The water will not come out of the door. The ice will work though.
My GE Profile has a system water filter. The manual said that if the filter clogs--it will not allow water to pass thru--any ice already made will still dispense but no new ice will be made. If you have a filter and it is over 9-10 months old, it could be clogged.
Jul 04, 2009 | GE Profile PSS26NGS Side by Side...
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice from ice maker smells and taste bad
We have a similar fridge: part of the issue could be with the filter, GE has a 6 month filter and a 1 year filter. Might be time to change it (I believe the MWF filter is one year, the GWF is 6 months). Changing the filter helped in our case.
But overall, if you leave lots of leftovers in the fridge, the ice will pick up the smell. A couple of boxes of baking soda should help absorb the smell before it settles itself in the ice.
May 17, 2009 | GE Profile PFS22 33" Artica French Door...
New ge fridge ice maker stopped producing ice
check filter or waler valve may be is the icemaker call service
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile arctica light not on for filter and is not making ice
change filter first if light stay on after changing filter change icemaker
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE fride
change water filter or there is a kink in the supply line
Sep 19, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
575 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
