Question about Audiovox VM9311TS
Sub jacks play but door speakers wont play when hooked up to proper wires why
    Problem Solver:
  • 7 Answers
Your car has a stock amp for the speakers hook up the blue wire that is on the stock lead wire harness to the remote wire along with the remote for the amp
Posted on Jul 02, 2009
Hooking up subwoofer to speakers
running subs with speakers is not a good idea bcs of the different frequencys of them but parrellel wiring is best prolly
+ to + and - to -
Nov 23, 2011 | Theater Research TR-2810 Main / Stereo...
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
My subs are ***
try taking one wire out of one sub, if the single sub gets louder than both then your wires are out of phase, if not then there is a prblem somewhere else.
Sep 10, 2009 | Alpine SWR-1240 Car Speaker
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Audiovox VM9311TS Logo
101 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
