Question about Philips DV910VHS DVD Player / VCR Combo
PHILLIPS DV910 VHS,DVD PLAYER WONT COME ON
VCR WORKS FINE TRY TOV GO TO DVD AND IT DOES NOT LIGHT UP AND MACHINE GOES BACK TO VCR MODE
jomaru
  • 337 Answers
SOURCE: Unit Keeps Powering Off...Will not stay on
The first thing you need to try is unpluging the unit from the wall totally then wait for about 5 minutes then plug it back in and try again,if you get the same results the cassete is probably stuck in the vcr and that is why the it unit shutsdown.It will continuo to do this until thye cassete is taken out without being force.The unit will need to be service by a professional.
Posted on Sep 26, 2006
shadow5599
  • 51 Answers
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
epik559
  • 44 Answers
SOURCE: DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Posted on Nov 25, 2007
markevans
  • 148 Answers
SOURCE: dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Posted on Dec 29, 2007
welcomejee
  • 10594 Answers
SOURCE: VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Posted on Sep 30, 2008
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
DVD/VHS Selection
turn of the power on wall, and wait 5 mins, then try again. i had same trouble with not being able to eject or play dvd, i turned off player at wall and it worked fine again.
Sep 25, 2007 | LG V181 DVD Player/VCR
This machine plays DVD discs fine but can only hear the sound with VCR tapes
Try first to clean the video heads then if that dosent work take in the machine to have the heads professionally cleaned. God Luck
Jul 27, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Philips DV910VHS DVD Player / VCR Combo Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
