Question about Raymarine GPS
I pulled the Raychart 620 Power cable plug apart. I need to know what pin goes into what hole to put it back together. One hole is marked B.
SOURCE: putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Posted on Oct 11, 2008
alicantecoli
  • 22326 Answers
SOURCE: timing marks for a vw 2000 jetta vr6
well learn how to time engine with no timing marks,its easy .look on end of cams for a slot or some sort of mark on the cam bearings caps .If you cant find anything then no 1
piston at the top and both valves closed with cam lobes in the air so to speak.dont forget to turn crank twice with a rachet before you evan think of trying to start engine.
Posted on Apr 18, 2009
wrench57
SOURCE: putting my airgun back together
http://www.flickr.com/photos/wrenchmonkey2k/
Posted on Jul 21, 2009
SOURCE: Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
Posted on Aug 09, 2009
SOURCE: crosman c11 airsoft gun assembly
best bet exploded view. i did the same thing
http://www.shans2003.ru/Article/pi_Crosman_C11_EVP.pdf
Posted on Aug 02, 2010
Instructions on how to install replacement screen on ddx616, brother broke screen then took it apart, lost screws, received replacement prts, just need to know exactly how to put it back togethe
I'm sure not many have attempted this repair but it's not going to be unlike most other repairs to this type of device. There will be blank sockets on the new screen with male pins that correspond to cable connectors on the head unit. You'll have to ensure that all open sockets are plugged into the cable from the unit on the new screen assembly. Electronic screws are fairly standard but if you're not sure take one out of the unit and take it to a hardware store to match it. ( I recommend ACE hardware). From there you just align holes and slots and start screwing it back together. good luck!
Feb 03, 2016 | Kenwood Car Audio & Video
What is the pin out for my motherboard
You do not state brand of motherboard. Any reputable brand such as Asus or Gigabyte will have a user manual download available that will have all the board pin outs shown. If the cables in the case are not marked you will need to trace them back to find out what they are attached to.
Jun 14, 2015 | Computers & Internet
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
I LIKE TO KNOW HOW TO KNOW WHETHER THE PRODUCT IS STILL FUNCTIONING OR NOT? PLEASE ADVISE. SHOW ME HOW TO DO THE CONNECTION OF THE IDE CABLE TO THE HARD DISC AND THE POWER CABLE? HOPEFULLY THESE ARE NOT...
No product support question is stupid, Peter.
1) An IDE cable should be plugged in with the Number 1 socket hole in the IDE cable's connector, going on the Number 1 pin on the harddrive.
Number 1 pin on an IDE optical drive, or harddrive, is next to the 4-pin power connection.
http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Illustration which shows the back of an IDE (PATA) harddrive.
See the area marked as IDE Connector?
Two rows of pins.
Next over are the Jumper pins in the Jumper Block.
Finally, next to the Jumper Block is the 4-pin power connection.
To make sure the IDE flat ribbon cable, is inserted into the harddrive in the correct position, a Locating Lug is usually on the IDE flat ribbon cable's connector.
A small rectangle, or two bumps side by side, on the top edge of the connector.
http://en.wikipedia.org/wiki/File:ATA_Plug.svg
This Locating Lug lines up with a cutout, in the circuit board of the harddrive.
A Locating Notch.
Sometimes there isn't a Locating Lug.
In this case look at the side edge of the IDE cable for the faint Red stripe.
This red stripe is on the same side as Number 1 pin.
http://en.wikipedia.org/wiki/File:Nappe.svg
So when you go to plug the IDE cable in, make sure the Red stripe is facing the 4-pin power connection.
Goes for an optical drive (CD/DVD drive), or a Harddrive.
(On the motherboard there are usually two IDE headers. {Connectors}
One for the Primary IDE device, a Harddrive, and one for the Secondary IDE device.
Usually an optical drive.
Next to the Primary IDE connector on the motherboard may be PRI, or Pri, or Primary, or IDE 1.
{ In TINY letter/numbers }
Next to the Secondary IDE connector on the motherboard, may be SEC, or Sec, or Secondary, or IDE 2.
Sometimes only the Secondary connector is marked. This tells you the other connector is the Primary connector.
Number 1 pin is towards the marking. Primary, or Secondary.
The Red stripe goes towards the marking on the motherboard )
Also;
There are two rows of pins on the back of the Harddrive for the IDE cable.
With a cursory glance it may look as though there are two rows of 20 pins.
There is not.
One pin has been removed. One row only has 19 pins.
Generally, but NOT always, the matching socket hole in the IDE cable's connector, is blocked off with a plug.
An IDE cable only uses 39 socket holes even if there are 40 shown.
Also; NOT a good idea to put a Harddrive, and an Optical Drive, on the same IDE cable.
BIOS looks to see which drive has the Master Boot Record.
Windows master boot record.
This is on the Harddrive.
BIOS will look at both, the Harddrive, and the Optical Drive.
This slows the computer down, for one.
For two, BIOS may not find which drive has the master boot record, with both drives on the same IDE flat ribbon cable.
Harddrive goes to the Primary IDE cable.
Optical drive/s go to the Secondary IDE cable.
2) As for the power cable it is a 4-pin standard Peripheral power cable.
Often misnomered as a 'Molex' cable.
[Molex was the model name given by the first company to produce this connector.
It stuck.
Kind of like referring to an open-end wrench as a Crescent wrench ]
It is also a STANDARD 4-pin Peripheral power cable, because there two 4-pin Peripheral power cables.
4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note in the center photo the shape of the connector.
The top two corners are rounded.
Only plugs in, in one direction.
{The Yellow wire is a 12 Volt wire.
Red = 5 Volts
Black wires are Ground wires }
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used this power cable for a Floppy Drive.
Newer computers use it for a Card Reader.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 01, 2011 | Computers & Internet
Fails to deliver water and shampoo when trigger depressed
hi, tip the vac on its back then look under the front where the water comes out, you will see 5 or 6 little round holes now the chances are these holes are blocked so get something long like a pin and poke these holes through you should find they are blocked with detergent that has turned to gel.
If after unblocking these holes it still dont work then you need to start thinking about following the pipe that runs to them little holes and clean these pipes out, you will find a blockage of detergent somewhere along the way.
Let me know how you get on or if you need further assistance ok
Nov 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need help reassembling my Crosman 1088....I had to take it apart for repair now im having trouble figuring out how the hammer mechanism goes back together correctly....I have the exploded view and parts...
Well.. it's really rather late, so I don't know if you're still trying to put the thing back together, but I was just having issues getting the hammer assembly on mine to work..
Going from this parts list: http://www.shans2003.ru/Article/pi_Crosman_1088-EVP.pdf
Assuming you had the same problem I did:
Start by putting the trigger assembly in (parts 37 and 40, the shorter pin on 40 goes through the holes on 37 as shown in the diagram)
Then insert pin 28 in to the hole that's right at the crook where your thumb rests.
Then part 35 goes over that pin with the little tiny nub pointing towards the back of the gun.
Spring 36 goes over that nub, and slides against the flat spot in the frame.
Pin 27 will then be placed in to the hole just above the hole for pin 28.
Then slide the hammer over said pin. now comes the tricky part. You will need something of moderate length, extremely thin and decently strong, I used an exacto knife. Use your tool of choice to press part 35 back, compressing the spring and push the hammer against the frame.
The two pins on the hammer should be in position such that the hook on the trigger assembly, and the crook on part 35 rest against them.
Once you have that done, keep holding the hammer in place, hook the spring hanging from it over the pin set in the frame. (should be pretty clear which one. and then re-assemble the rest of the gun.
Be warned spring 29 does not like going back in. you will likely feel like you need 3 hands (one for the hammer, one for assembly 60/spring 29 and one to put the frame back on.
Hope it helps.
Nov 10, 2009 | Sport & Outdoor - Others
I need to know if I put it back together right
If you pulled it apart and put it back together but now it won't work properly, try checking your IDE cables to the hard drive/cd-rom, make sure they aren't connected backwards. Otherwise just carefully look over the entire board, be sure that the processor, heat sink and fan assembly are all intact and connected properly, do the same with the RAM, power connection, any expansion cards.
May 06, 2009 | Computers & Internet
Motherboard Pinout - Please Help
here are some sites that may help you.
all these should be marked power switch may say pw,prs,ps, power led may say pld, pl,led, hhd say hd, reset switch maysay rs, set, these connection will be grouped together, and pin layout 1 red or hot wire, or the main wire for the device you are trying to operate.
www.motherboards.org
www.tomshardware.com
www.twinight.org/chipdir/
www.anandtech.com
the connections to the back plate is standard the amount of pins match up the cable, the number 1 pin will be marked some how and or the cable will only be able to plug in one way.
with an exception if you are using serial connector and we hardly use them. the rules are the same as above, and plug ins maybe one way also.
the ribbon type will have a marking on the cable or ribbin line or dots or hasshs marks that is pin #1
match with pin out on motherboard pin1 or pin 0,
rod
Feb 11, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
Connection cable on system board
power supply and or needs battery in it too work in conjunction with each other on toshiba
the connector cord for compaq now it could have left outside comp for external cd or hdd but im going to say its the power connector or too hdd
but if you give me description of connector i will know where it goes
May 09, 2008 | Compaq Armada M700 Notebook
Symphonic 13 inch tv vcr combo
Solution steps:
1. Make sure that the cable is not plugged into the mains receptacle.
2. Open up the unit
3. Inspect the board. Look out for a glass fuse rated about 3A/220V near one corner of the board. It is close to the mechanical ON/OFF switch on the TV. The cable normally plugs into a socket made up of two vertical pins an inch or less from the fuse. Sometimes these are marked with a squiggle (~) or two (~~) to signify that the mains power goes there.
4. If the cable terminator (end of the cable opposite the mains plug) was cleanly pulled out, then well and good. In that case simply plug it back in. If not (i.e. the cable is damaged, then you may have to remove the terminator and solder the cable directly to the board.
5. To pre-empt any further "pullings", make a knot on the cable inside the TV where the cable comes out so that there is some resistance to the pull.
6. Close the unit and enjoy.
Jan 21, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
GPS Logo
90 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
