Whirlpool Washing Machine Balance Ring
I have a whirlpool washing machine, LXR7133JQ0, that the balance ring has come totally loose from the inner tub. I can see the metal clips that should attach it. Makes horrid noise so i stopped the load and found the balance ring separate from the tub. I need direction on how to replace this. I have done some other work on this machine (proud to say my hubby calls me the Maytag Repair Woman!). Also saw on another site to order the Filter Plate (item #14 in diagram) in addition to the Balance Ring and Clips. Is this necessary? HELP...
  • Anonymous Mar 21, 2014
    need tub ring pic, & to order one
This is now 2009 the machine you speak of is a piece of junk so by now its probably trashed you don't need my help
Posted on Jan 21, 2009
  • tongyun59 Jan 16, 2013
    What a stupid and useless comment.
    louannhere, what a stupid and useless comment .
Whirlpool top load washer is running across the floor. I've replaced all springs. I've also made it 100% level. What's the next step?
The following images identify an invention that most newer machines included, The ring about half filled with water automatically balances the basket of the washers. If the water has leaked out or the ring has failed the machine will not achieve balance. The ring is replaceable by qualified DIY.
Most units only have the ring on the top of the basket, but some as the bottom image shows have two.
Hope this helps?
Mar 29, 2016 | Whirlpool Washing Machines
Wirlpool wtw4800xq washer frequent out of balance
Check the spring rods on each corner make sure not broken or came off pull basket make sure nothing in between silly question is it level also check the balance ring to make sure it is not loose
Feb 17, 2015 | Whirlpool WTW4800XQ Top Load Washer...
Washer is always of balance
Is the machine level? Does it rock if you push down on any corner? The machine must be level with all 4 feet firmly settled on floor. If you are satisfied level is good then open the loading door and move the tub back and forth (kind of vigorously, but no need to get carried away.) You should hear sloshing sound from the balance ring. If no slosh balance ring will need replaced.
Dec 29, 2012 | Whirlpool WTW6400SW Cabrio Washer
Maytag mah55flbwq not draining
Perfectly normal..
What you are actually hearing is a balance ring on the inner tub that has liquid inside to help keep washing loads balanced.
The balance ring is filled with a calcium chloride solution and baffles within the ring allow the fluid to disperse within the ring evenly
By rotating the spin basket you can hear the fluid dispersing within the baffles of the balance ring.
Thebalanceringisfilledwithacelciurnchloridesolutionandbaffles,withintheringallowthefluidtodispersewithinthe:ring,evenly
I also thought ours was not draining properly but discovered otherwise when I had to take the inner tub out for a bearing repair job..
Hope this puts your mind at rest..
Aug 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
After using my Whirlpool Cabio Top Load Washing Machine to do a load of laundry, I can still hear water sitting inside.....What can I do?
There water in the balance ring at top of basket/that has to be in it...Can you see water at bottom of basket?
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Missing balance ring clips on whirlpool washer model # LXR9445JQ0
just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
http://www.partselect.com/PS874751-Whirlpool-3956205-Balance-Ring-Top-of-Inner-Tub-White.htm?SourceCode=1&SearchTerm=LXR7244JQ1&ModelNum=LXR7244JQ1#Instructions
Jul 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
I hear water in the washing machine when move it and think maybe water is building up in the machine. What should I do?
What you are hearing is the liquid inside the balance ring at the top of the wash tub. You could set the machine in the center of your driveway and drain every drop of water from the hoses and pump, yet you would still hear the liquid in the balance ring when the machine (more specifically, the inner tub) is moved. It needs to be there to help balance out of balance wash loads.
Apr 10, 2010 | GE WJSR2070B Top Load Washer
At end of spin cycle,machine seems to be out of balance. Vibration and noise are severe
1=WASHER MUST BE ON SOLID FLOOR,IF YOU CAN FELL IT SHAKING 2FT OR MORE BACK FROM YOU,YOU HAVE A WEAK FLOOR.
2=BALANCING RING BAD,REPLACE ..
3=MAKE SURE THE TUB IS NOT LOOSE
THANKS LACUZ12
Feb 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Can you repair balance ring/tub unit on whirlpool direct drive washer or must you just buy a new tub? I think the fluid has leaked from the balance ring.
some units had balance held in place by clips those could be replaced separately those where balance slipped around outer edge of tub are not a separate part that can be ordered
Sep 17, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,925 people viewed this question
Top Washing Machines Experts
