That's actually a mica "window" (cover) for the microwaves to come out. And it sounds like the magnetron started arcing and burned a hole in that cover. Either that, or some food (frequently spaghetti sause) got splattered on it, and the microwaves heated it up so much that it burned a hole in the cover. Does the microwave oven still work (heat)? Do you see or hear any arcing? If the microwave oven still works and there is no arcing, you can just replace that cover. Check SearsPartsDirect.com or RepairClinic.com.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: lightning inside microwave oven
You better be carefull my friend or you will start glowing in the dark!! LOL Just kidding. But I wont kid about how dangerous that metal cylinder can be with the holes in the top. Thats the magnatron. It has very high voltage going to it and you should never ever touch any wires going to it even if its unplugged as theres a capacitor in there that holds a charge for a time. f the oven is over several years old, Im sure the magnatron will cost more then a new oven, after you add labor and such. It just migfht be time to upgrade to a new microwave?? Good Luck
SOURCE: IS MY MICROWAVE NOW UNSAFE TO USE - CAN I DO OWN HOME REPAIR?
It sounds like what you are describing is called a "waveguide cover". You can purchase a replacement from a local parts supplier, or on-line at www.repairclinic.com. It is very easy to replace.
SOURCE: Inside top of microwave has a burn hole in
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
