Question about Mtd 22" Yard Machine Push Mower
I have a yard machine 400 series front engine lawn tractor.
I had a problem with it starting, It would run for a few minutes then stall out. I took the carburetor off and cleaned it my problem is that I need to put the carburetor back on and I forgot how the throttle lever goes back on and also how the governor lever goes back on. I should have taken pictures. I have the repair manual but it does not show a picture of the engine or any of the levers.
  • 6 Answers
SOURCE: I HAVE A MTD YARD MACHINE 12A446B729. RUNS FIVE
was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
  • 12 Answers
SOURCE: Lawn tractor jerks when driving across lawn
Can you adjust tensioner
Posted on Jul 20, 2009
  • 125 Answers
SOURCE: yard machine mtd 123cc mower stalls after starting
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Posted on Aug 16, 2009
  • 138 Answers
SOURCE: Mower starts, but dies immediately
that's not a choke lever, it's used as a speed control on some models. the two springs are attached to the governor rod, which is attached to an "air vane" governor - on these engines, you need to keep the gas tank fairly full at all times, the dip tube on the carburetor rides up off the bottom of the gas tank, if fuel level goes lower than this tube, it won't pull any gas to the intake - from your descriptions, though, it sounds like the diapragm between the carb and gas tank has "curled". briggs had a service flash on the problem and since it's new, you should take it to a shop that does briggs warranty work - it should be covered under warranty
Posted on Aug 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a Yard Machine Lawn Motor with a 4.5hp
Pull apart and clean the carb. You can dismantle and soak the carb in solvent or equivelant for a couple hours. A dirty carb and poor spark are the major reasons that the motor won't run well.
Posted on Sep 21, 2009
It stalls after running fine for 30-45 minutes
Hi James:
Thanks for providing an extremely detailed history.
My first reaction was similar to yours............ sounds like a fuel supply obstruction, but you seem to have covered it extremely well.
There are two other things you may consider checking.
1) When the stalling occurs, shut off the engine and pull the spark plug(s). Check the appearance of the electrode, wet indicates firing (spark) problem, dry indicates fuel delivery problem. While the engine is still hot, reconnect the plug lead, hold the plug against the head, then spin it over and check the spark. You're looking for hot and blue.
2) Exhaust obstruction. Remove the muffler and make sure that there is no carbon buildup or defective baffle that could be causing excessive back pressure.
If you reply as a comment to this post I'll get your feedback.
Cheerfuls
Ted
Nov 06, 2015 | Garden
Yard pro estate series
No it does not. LoL
Jul 15, 2013 | Garden
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
My ride on runs well for about half an hour or less then starts to lose power then stall will restart and then stall again in a few minutes
Try loosening the gas cap just as it begins to lose power. If this clears the problem, clear the vent holes in the cap.
Gary
Feb 06, 2011 | Yard Machines Garden
Lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Sep 19, 2009 | Garden
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Mtd 22" Yard Machine Push Mower Logo
180 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
