the abs and brakes are related, but not brakes are not dependent on abs. you mentioned you got new brake pads and the brake pedal got fixed? if it didnt get fixed, then your master cylinder might be going out, its the only logical thing if you bled your brake pads. about the abs, it stands for anti-lock braking system. what it does is at instant high speed stops, it pumps your brakes very fast to stop your wheels from locking up, which prevents your car from skidding, and allows you to manouver your steering wheel as you are braking. very helpful, but not essential. it is like passanger or even drivers airbags, definately better to have, but not essential. if you dont have money to fix your abs right now, dont worry about it, as at least half the cars on the road, including newer, basic cars are not equiped with abs. another thing, abs is a relative new technology, which became common in the 1990s, which means before that, cars didnt have abs, so if someone says to fix it right away because it is 100 percent dangerous, they are just exagerating. just take a little extra precaution while braking, thats all. on the other hand, if you do have the money to fix the abs, you can start by retrieving the code first using a paper clip:
http://www.cb7tuner.com/vbb/showthread.php?t=21259this will lead you in the right direction. hope this helps, and if you need any help, leave a comment and ill gladly respond. goodluck
