Question about GE DBL333EA Electric Dryer
Dryer when I turn my dryer on it sounds like power but nothing is going so I went and to the top off and the front off like a car as the suggest was and the drum belt is good I started turning the blower with my hand and it spins so now don't know what to check for now
  • capcorvair Jan 05, 2008
    my GE dryer only hums when I try to push the start button and seems like a slite dim of the lights in the room let off start button and nothing happens and not getting any noise from timer.
Almost certainly the capacitor is defective.{small plastic sylinder with with 2 wires connected). if it runs after you turn fan with hand, thats your problem.
Posted on Nov 15, 2007
  • 25 Answers
Check the front door switch for a clicking sound; in no sound occur, change the door switch.
Posted on Nov 08, 2007
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a 6 year old dryer mod # teds840q0 , and was drying a load and when I went to start another load nothing would happen. when you hit the on off switch it will click and nothing. replace switch
Sorry to read about your problem, I hope this helps you out.
The start switch could be defective, but it sounds like your motor has failed. I would let the dryer cool down, and see if it starts..if it starts again. i suggest you check you dryer vent lines for clogs, and also from the wall to outside of the house.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Estate Dryers
My dryer won't turn on it works great but suddenly I can't turn it on. When I push the button to start there is nothing.
The dryer functions are all impaired if the motor doesn't run. The heating circuit is activated only when the motor runs because power to the heating element is routed through the motor centrifugal switch. The problem here is likely a blown thermal fuse because power to the motor is routed to it. The motor cannot therefore run if the thermal fuse is blown.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Whirlpool WED5200T Electric Dryer
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2002 kenmore dryer
Either the top pries up or at the bottom of the front panel you'll see 2 screws. If screws at bottom take out and lift off be sure to disconnect door switch wires before removing door completly. If it's pry top up use flat screw driver at about inch and a halh in from edges pop the top up and open then inside front panel toward top you'll find 2 more screws take them out and front panel should come off. Good Luck
Nov 01, 2008 | Kenmore 63942 Dryer
Dryer heats up but won't turn
Perhaps you have a broken drum belt
May 20, 2008 | Whirlpool LEB6200 Electric Dryer
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Oct 18, 2007 | Amana DLE330RAW Electric Dryer
GE DBL333EA Electric Dryer Logo
57 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
