Question about Refrigerators
Fridgedaire frt22rha wont stop running - Refrigerators
    President:
  • 744 Answers
Your problem is with the cold control, it is either a thermostat located in the panel inside the refridgerator, or it is built into a control board located inside a panel rear of refridg...the cold control has got stuck open which is why it is constantly running. replace the control and you should be good to go. Hope this helps, If you have any other questions or concerns please feel free to comment again - please do not forget to rate my solution...Good Luck!
Posted on Jun 29, 2009
My fridgedaire washer wont spin onspin cycle?
There is not enough info and need model number
Jun 14, 2014 | Washing Machines
Fridgedaire #FSG748GFS wont start,buzzes when start knob turned
MAY BE BAD THERMAL SHUT OFF FUSE OR BAD START SWITCH U NEED TO CHECK WITH A MULTIMETER
Apr 10, 2014 | Frigidaire Dryers
OVEN Timer ALarm stuck ON & cannot stop beeping
Try unplugging it and letting it reset itself.
May 18, 2012 | Kitchen Ranges
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
FRIDGEDAIR WALL OVEN fec50k1 JUST STOPPED WORKING, CLOCK ETC WORK BUT NO POWER TO ELEMENTS FUSES OK
you need to replace the main control board or set it up for service to check the internal fuses
Sep 27, 2009 | Frigidaire (FEB30S7D) Oven
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Fridgedaire glrs237zcb3
about the only thing you can do here is take the back cover off the unit see if the cooling fan for the compressor is running if it is and there is an Indian on the compressor then the compressor should be replaced if the fan isn't running then clear the fan once its running then turn the unit off for 30 Min's and try again
Feb 11, 2008 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
