Question about Air Tools & Compressors
I need the Manual For Wagner Paint Crew 660 - Air Tools & Compressors
    Problem Solver:
  • 13 Answers
Try this link
http://www.wagner-group.de/portal/color_w_660_en_wag,857,365.html
Posted on Aug 21, 2009
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
May I have the manual for a WAGNER PAINT SMART electrical spray gun. thank you
nozzle head might be shut try turning it to open, you should here air coming out if air comes out but no paint comes out then paint is to thick and might need thinning, hope it helps.
May 20, 2014 | Wagner Spray Tech Air Tools & Compressors
Wagner paint crew model 770
It doesn't take much residual paint to dry out in hose and block it.Have you lowered the paint pressure?
Wagner 770 Owner Manual Page 8
Nov 27, 2017 | Air Tools & Compressors
MANUAL FOR WAGNER MODEL 770 I NEED A MANAUL FOR THE WAGNER MODEL 770
Here you can find the manual: http://www.portlandcompressor.com/docs/Paint-Crew-manual.pdf
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Jun 20, 2011 | Air Tools & Compressors
Finding a booklet for a Wagner 770 paint sprayer
You can find a manual here: http://www.portlandcompressor.com/docs/Paint-Crew-manual.pdf
Michael
Jun 21, 2010 | Air Tools & Compressors
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Jul 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
1,290 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
