Question about Dell Power Supply 330 Watts nps-330cb (NPS330CB) Power Supply
Dell NPS-210AB power supply starts up then shuts off
I am trying to use the a dell nps-210ab power supply +12 VDC output to power a car radio.
I have it plugged in and short pin 14 to ground and the fan starts for only about 1 second, I measure rising DC voltage on the +12 V pin but it never reaches +12 volts, it just goes back to zero.
It acts just like a car that starts up then immediately stalls.
Any help would be appreciated.
Thank you,
Bob
  • rpmour Jun 29, 2009
    I tried a single 12 volt automotive bulb but that did not work. I will apply a load to all lines and see if that works.
    Thank you Verosaka
  • rpmour Jul 02, 2009
    Verosaka,
    Your suggestion worked. I loaded the +5 V line with an indicator lamp and the supply works now.
    Thank you for your help.
    Bob
    Problem Solver:
  • 7 Answers
Hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Posted on Jun 29, 2009
  • Anton Todyka
    Anton Todyka Dec 03, 2015
    Reed below my comment. Will be a bit clear for simple people like me :))
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Put 5 Watt resistor between Ground (BLACK wire) and 5V ( RED wire).
Or Just connect PC FUN / COOLER to RED and BLACK wires.
AND also don't forget connect Green and ANY Black (Ground) wire together to start power supply Unit every time.
Power Supply unit will start on every time you give connection between Green and BLACK wire.
Tested with my Dell NPS-210AB works perfectly. It is all about putting a phantom load ;))
Second option:
If you do not have cheap 5 Watt resistor from Ebay.
Use any hard disk. Just connect it as usual only with POWER connector. It will work as a phantom load ( 5 Watt resistor).
Posted on Dec 03, 2015
There is only one green wire and only one grey wire among all the wires ; just bridge them and the power supply will stay on.
Posted on Jun 22, 2010
  • Anton Todyka
    Your way Tested. Did not worked :((
Set up New PC Studio that is NPS then install USB drive
i have to install PC studio in my PC but when i tried it shown that my PC does not have NPS therefore it can not be installed. tell me how to install NPS.
May 30, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
I have a problem with dell nps-210ab. When i plug in power cable and without presing a button to start a computer cpu fan start turn very very fast it seam like he will fly away. No bios sound. Nothing
That is indicative of a Power On Self Test failure of the system. Remove all peripheral connections, all expansion cards and RAM and see if the symptoms change. If they do not, then replace the motherboard
Mar 02, 2010 | Dell Power Supply 330 Watts nps-330cb...
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Dell power supply NPS-210AB will not turn on
Try switching it with one that you are certain works just to make sure it didnt blow or that your computer is working alright. or, using a multimeter, try and check for any current flowing to any of the connectors...
Jun 21, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
No power on
if sb +5 is ok then check one by one these component :-
check main swithing transistor for open
check diode, capesetor and 3.3 ome resitor it may be open after then check
+ 12 to +18 volt for pwm ic and ,
if votage is not missing then change pwm ic
Apr 21, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Use nps-330ab for a normal power supply
You need to ground pin 14 momentarily to turn the power supply on. Pin 10 provides +12v, pin 12 provides -12v. Diagram here.
Apr 15, 2009 | Dell Power Supply 330 Watts nps-330cb...
Dell - nps-200pb-73M not working
dont know the AC and the DC of my NPS-200PB-73M
Apr 25, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Computers & Internet Logo
1,661 people viewed this question
Alun Cox
