Question about Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same diagnostics: several beeps and the power light blinks continuously. What is the problem and how can it be fixed? Also, where can I get a user manual for this system? None on sunpentown.com.
  • 22 Answers
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
Hi my wa-121oe is not blowing cold anymore
hi.maybe your compressor not working maybe you need charge.
Jul 16, 2014 | Sunpentown WA-1210E Air Conditioner
Sunpentown WA-1210E
The unit is probably undersized for the space. Rule of thumb is 12000 btu per 500 sq ft. Take a thermometer and measure the entering air to the unit and then hold it in the outlet air stream you should see a temp. difference of about 10 to 15 degrees if it functioning properly. Hope this helps 2rns4u <*{{{>(
Jul 22, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Air conditioner
filters blocked or fan cage full of dust cant pickup the air if this is a zoned system then maybe zone damper is stuck not letting the air through
Jun 20, 2009 | Sunpentown WA-1210E Air Conditioner
My unit turns off by itsself
Probably is the problem. These units have a float switch in them and won't run if they fill up to protect your floor. What you can do is connect a tubing to the drain pan and either drain it out side or into a larger container. Hope this helps 2rns4u <*{{{>(
May 10, 2007 | Sunpentown WA-1210E Air Conditioner
Sunpentown WA-1210E Air Conditioner Logo
505 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
