HP laser jet 9000
I have an error code of 59.1. I have changed DC controller board, formatter board, Power supply both low and high voltage, duplexer, drive motor but not the drive gears, and cartridge. At turn on it starts up and shortly turns the main drive motor then gives the code. Can you help?
  • Reg Chandra May 11, 2010
    %9.1 error is main drive motor not rotating at startup.Drive still not working,either motor doa or board connected to.
    President:
  • 2,306 Answers
Does it have a generic toner installed? Many of the generics are too hard to turn at first and will break gears and stall motors. Can you turn on without toner installed?
Posted on Jun 29, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
41.2 error hp laserjet 5200
41.2 error hp laser jet 5100
am from Ethiopia but when am check and replace the Formatter board ,beam not working but when am replacing the DC controller and all connecting cables to beam, then it was working god .
Feb 04, 2014 | HP Hewlett Packard LaserJet 5200 Printer
How can you fix 58.04 cp3525dn laser jet printer hp?
58.04 ERROR
To continue turn off then on
The low-voltage power supply has
experienced an error.
1. Check the connector J1143 on the DC
controller PCA.
2. If the problem persists, replace the low voltage
power supply.
Sep 11, 2013 | Office Equipment & Supplies
My problem with my HP Color Laser Jet 2600n printer is, it does not initialize and the 55.1 error appears in the screen
Internal communication has occurred. Check the power source. formatter board or the DC Controller board could be faulty.
Good luck
Apr 21, 2010 | HP Color LaserJet 2600n Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
May 15, 2009 | Office Equipment & Supplies
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Hp Laserjet 8150 LVPS replacement
It is located in the back of the printer on the bottom. Remove the back cover. With the power off, remove the formatter board by loosening the two big screws and pulling out. Remove the plastic cover by the side of the formatter cage. Remove the fan housing by the power connector by removing the two screws, disconnect the cable and pull straigt out. Now remove the big cable at the top and unwind from the high voltage ps. Remove the white connector in the middle of the low voltage ps. Next trace the white cable wires running from the ps to the dc controller and remove the cable from the dc controller. Now trace the fan cable for the fan in the front of the ps and remove it from the dc controller. Remove all the screws which secure it to the frame and pull straight out. Move the fan in front from the old ps to the new and reverse instructions...
Take off the large metal side cover. Look down at the bottom of the printer. The large box is the LVPS. Remove the screws holding it and follow the wiring up to where it plugs in and pull the connectors off. You'll also have to remove the fan above the LVPS on the top right side of it. You will have to take the fan mounted on the LVPS off and put it on the replacement LVPS as they don't come with fans.
Oct 23, 2007 | HP LaserJet 8150 Printer
k24674
jasbo
jasbo
