Question about Rohl TWO-BOWL FIRECLAY APRON KITCHEN SINK - RC-3719-BK - Black
Can a chip in a Rohl shaw fireclay apron sink be fixed?
  • 29 Answers
Yes with epoxy
Posted on Jul 21, 2009
I have a rohl model r77v3 faucet. is it supposed to rotate on o ring on top of counter? or on the base ring?
All the info is here. Trim Ring, O-ring, Counter.
[PDF]R77V3 (Metal Lever) R77V3LP (Porcelain Lever) - Rohl www.rohlhome.com/pdf/R77V3.pdf
  1. Cached
  2. Similar
R77V3 (Metal Lever). R77V3LP (Porcelain Lever) www.rohlhome.com. Consult your local ROHL showroom for additional information and specifications.
[PDF]ROH8734 Maint Bro_f.qxd - Rohl
https://www.rohlhome.com/pdf/489.pdf
  1. Cached
R77V3 (Metal Lever) www.rohlhome.com ... For complete warranty details and a list of showrooms, go to www.rohlhome.com. ... NOTE: MODELS MAY VARY ...
Rohl R77V3 Single Lever Pull-Out Kitchen Faucet with Metal Lever ...
https://www.ajmadison.com > Sinks & Faucets > Faucets > Pull-Out
  1. Cached
Rating: 3 - ‎3 reviews Brand: Rohl. Series: Country Collection. Model: R77V3. Dimensions. Faucet Height: 8 1/2 Inch. Faucet Reach: 9 Inch. Base Width: 2 3/8 Inch. Cutout Size: 1 3/8 ...
rohl model r77v3 Google Search
Dec 02, 2016 | Rohl Plumbing
How do I secure my Rohl "country bath" drain to the sink?
That drain sounds about normal, Dave. What sink are you trying to attach it to? That sink may require a special drain.
The square holes are for the overflow, which takes water in at the overflow port (usually under the front edge of the sink) and routes that water under the bowl - the bowl usually has two layers - to the square holes, where it turns & goes down the pipe. If your sink has no overflow, there won't be a second layer for the bowl, and that drain won't work.
Aug 02, 2014 | Rohl Plumbing
Can a defective Rohl apron front sink be pulled and reinstalled?
Generally these sinks are placed into the cabinet in a cradle and then the countertop material is set "over" them for an undermount look. To remove the sink you would need to cut the front of the cabinet and also remove the cradle to drop it down and out, the only other way would be to lift off the countertops, which may not be possible depending on seams and if tile backsplashes are already installed.
Oct 18, 2013 | Plumbing
Can I drop-on this sink? or only undermount it? Thanks, Brooke
You are only restricted to undermounting these sinks because of there depth in relation to the siting of the tap, that's all. Remember if you place this sink on top you willhave to discreetly raise the tapbase fixing to maintain easy use of the taps
Jul 15, 2011 | Franke MHK-720-31-MB Fireclay Double Bowl...
I have a white Franke fireclay sink. We also have very hard water despite using an undersink filter. The sink is part of a new remodel and despite little use so far and lots of wiping, the water spots seem...
The best product I have found to remove water spots is a product called A-maz water stain remover in a 14 oz tub. There is no magic "wipe on,wipe off" product that I have found. Initially it is a little labor intensive but this is amazing stuff and can return your sink to its original luster.
This company also make a sealer but I have not tried it. A couple of alternatives might be Rain-X or Maguires auto wax. The concept here is to put a barrier down that will seal the pores of the sink and make it easier next time to remove the spots. My favorite is Maguires about every 3 months. I have provided a link below to the A-maz web site where you can find a distributor nearest you.
http://www.a-maz.com/
May 10, 2010 | Franke Double Undermount Fireclay Sink -...
I Have a FRANKE Fireclay white Farm sink only 90
E-mail the manufacturer from this page.
http://www.frankekitchensinks.com/link_to_us.htm
Sep 04, 2009 | Franke Plumbing
How to repair a chip in a fireclay farmhouse sink
Try a product called "Pratley Putty" if you can find it at your local hardware. It is a two part epoxy putty that you mix and then use as a repair agent. If you cant find it locally, e-mail me via FixYa, give me your details and I'll try source some for you or find out from the manufacturer who is local for me if thjey have an outlet in your area.
Jul 05, 2009 | Home
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
I have a brown colored stain in the bottom of my white franke white fireclay sink (maybe coffee stain, not sure) I can't get it clean with regular hand soap which is what franke told me to clean the sink...
I used Cerama Bryte for the dark colored stain, I left it on for about 5 minutes and then rubbed it clean, the stain is gone. Now I tried it on the small aluminum scratch marks, no thank you, it couldn't help that problem. Still seeking a solution. Thanks
Mar 02, 2009 | Herbeau Creations HERBEAU "Luberon" Art...
Rohl TWO-BOWL FIRECLAY APRON KITCHEN SINK - RC-3719-BK - Black Logo
502 people viewed this question
Top Rohl Home Experts
john h
Tom Chichester
Are you a Rohl Home Expert? Answer questions, earn points and help others
