Question about Honda Pressure Washer PSI 3000
I need to know the torque specs for the rod cap on a 2750psi pressure washer
  • firehead May 11, 2010
    What is the engine type and model number???
3 Suggested Answers
  • 22 Answers
SOURCE: NEED TORQUE SPEC FOR CONNECTING ROD BOLTS ON GX390
the torque setting is 16nm,hope this helps
Posted on Mar 30, 2009
  • 110 Answers
SOURCE: what are the head and rod bolt torque specs on a
one hundred ten inch lbs on the rods and 45 ft on the head bolts
Posted on Nov 15, 2009
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
Torque specs for rod & main brgs for 1994 ford f150, 300 6 cyl fuel inj engine
Main Bearing Cap Torque:
Torque in 2 steps: Step 1: torque to 35 Ft/Lbs Step 2: torque to 70 Ft/Lbs
The Rod Bearing Cap Torque: 45 Foot pounds (Final torque)
Was this what you needed...let me know by your rating of me...thanks!
Sep 17, 2011 | 1994 Ford F150 Styleside Supercab
I am looking 4 the torque pressures (ft.lbs) on the main crank bearings, and rod bearings on a 2007 Ford 5.4 3 valve engine??? Gerry..............thank-you
mains - vertical bolts first 30 ft.lb. PLUS 90 degrees
pattern frt
8 7
4 3
2 1
6 5
10 9
side bolts
22 ft. lb plus 90 degrees
pattern frt
7 8
3 4
1 2
5 6
9 10
connecting rod caps cracked type rod-rod and caps must be kept in matched sets, recommend new bolts/nuts, spec is 32 ft lb. plus 105 degrees - torque each item to the correct torque then go back and do the degrees. these are torque to yield bolts and the procedure is very important.
Oct 02, 2010 | Ford F-150 Cars & Trucks
Need to know torque spec. on main & rod bearings 4 cycl.
1997 Nissan/Datsun Truck Pickup 2.4L SFI 4cyl
The Main Bearing Cap Torque:
38 Foot pounds (Final torque)
Torque sequence:
Step 1: Torque to 10-12 Ft/Lbs
Step 2: Torque to 28-33 Ft/Lbs
Hope help with this (remember rated this post). TY for using Fixya.
May 19, 2010 | 1997 Nissan Pickup
Need torque specs for 1999 Ford 3.0 rod & main bearings
ft lbs
Main Bearing Cap Bolts 75-85 56-62
Connecting Rod Cap Nuts 31-39 23-28
May 27, 2009 | 1999 Ford Taurus
99 dodge intrepid specs
Inner main bearing cap bolts:
Torque to 15 ft-lbs, then rotate an additional 1/4 turn
Outer main (windage tray) bearing cap bolts:
Torque to 20 ft-lbs, then rotate an additional 1/4 turn
Main bearing cap cross bolts:
Torque to 250 in-lbs or 20.83 ft-lbs
Connecting road bearing cap nuts:
Apr 21, 2009 | 1999 Dodge Intrepid
Need torque specs
Torque sequence:
Step 1: Torque 29 to 34 Ft/Lbs
Step 2: Torque an additional 90 to 120 degrees
Oct 14, 2008 | 1997 Ford F150 Regular Cab
Honda Pressure Washer PSI 3000 Logo
56 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
