Question about M-Audio MicroTrack 24/96
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
So frustrating. I press file, record, (if I even can get that far) and then it stops recording after 5-7 minutes!! I NEED to do an interview today and can figure the darn thing out.
HELP!!
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Posted on Jan 02, 2008
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
Power out. how do I reset clock GE DECT 6.0
Make sure the answering system is ON.
Press and hold the DAY/CHECK button to set the day of the week.
Press and hold the HOUR button to set the hour (a.m. or p.m.).
Press and release the MIN button to advance the clock in one minute intervals. Press and hold to increase by 5-minute increments.
After the time is set, the real time clock will be displayed on the handset within 1 minute.
NOTE: You must set the day manually. You may choose to set the time manually as well, although the time is automatically transmitted by your local phone company as part of Caller ID service. If you subscribe to Caller ID service, the current time is set automatically when you receive your first CID record.
Sep 22, 2011 | Thomson GE 27907GE1 Cordless Phone
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
How do I change the time on the radio in my '08 pontiac g6
To set the hour, press the CLOCK button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the CLOCK button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Nov 07, 2010 | 2008 Pontiac G6 Sedan
How do I set the time on the radio for a 2002 f450
To set the hour,
press and hold CLK until CLOCK
SET appears in the display. Press
SEEK to decrease or
increase the hours.
To set the minute, press and hold CLK until CLOCK set appears in the
display. Press TUNE to decrease or increase the minutes.
Sep 07, 2010 | Ford F-450 Cars & Trucks
How do I set the clock on the radio cd/cassette?
Setting the time:
Hour: Press and hold the CLK button and at the same time push the SEEK button < decrease the hours > increase the hours.
Minutes: Press and hold the CLK button and at the same time push the TUNE button < to decrease the minutes > increase the minutes.
Jul 14, 2010 | 1999 Ford Explorer
How to get a message on a telstra m450 answering machine
To change the answer message, hold ans on/off then HOLD the skip back button, don't let go until you finish the message, to change the amount of calls untill it plays the answer machine hold skip forward button till it says how many the press the forward button till you are happy, to change date and time, hold stop, it will say the day to change press skip forward, then press stop again, it will say the hour, press skip forward, then stop the minute, then skip forward, then stop again to confirm, i belive it is in 24hour time as well, when changing the time, but not on playback.
Hope this helps
Feb 08, 2009 | Lands Phones
Setting the clock on a deh-1400 radio
Setting the time
This is used to set the time on the unit’s clock
display.
1 Press SOURCE and hold until the unit turns
off.
2 Press AUDIO and hold until TIME (12:00)
3 Select the portion of the time display you
wish to set with
2/3.
Pressing 2/3 will select a portion of the clock
display:
HOURMINUTE
As you select portions of the clock display the
portion selected will blink.
4 Select the correct time with 5/.
Pressing 5 will increase the selected hour or
minute. Pressing ∞ will decrease the selected
hour or minute.
• To cancel time settings, press BAND.
• You can also cancel time settings by holding
down AUDIO until the unit turns off.
Please rate, thanks
Sep 15, 2008 | Car Audio & Video
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Setting clock
1.Press and hold the (BND) button, then press the (DISP) button to display the clock display.
2.Press and hold the (BND) button, then press the (DISP) button for about 2 seconds (the number will flash).
3.Press the << button to toggle between hour and minute selections. Then turn the ROTARY(volume) knob to increase hour/minutes.
4.Press the (BND) button, then the clock is set!
Kurz
Apr 07, 2008 | Clarion DB245 CD Player
M-Audio MicroTrack 24/96 Logo
308 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
