BT was working before with W7 but after changing power jack it is not recognized as being present.
SOURCE: i bought a dell inspiron
Install the bluetooth drive ,you will got the error message that you havn't switch on the adaptor ofcourse the radio buttons are in on position. Click the cancel button. Be sure the radio buttons are in on state. Now you go for "C:\Dell\drivers\R140135\3100_216\" there you can see a sheld icon with the name "inst" in the further folders(search the folders for inst sheld icon), double click and run the software installation and finish the installation.Now restart the system and now you can notice a bluetooth icon in inactive stage in the notification area , right click on it and turn on the bluetooth adaptor on. Now the bluetooth device was ready to use, the problem is solved.
SOURCE: Driver for Dell BT Travel Mouse
If it is a dell mouse, it should automatically work after a few things. Simply locate the button on your mouse to power it on, open your bluetooth settings on your computer and scan. It will then add the drivers as a HID (human interface device). If that fails go to dell.com, search for drivers & downloads under support and search for the drivers & documentation.
SOURCE: Where is the bluetooth Module/Adapter located at
Turn the computer off.
Disconnect the AC power.
Flip it over.
Remove the battery.
Look at the various "covers" that are screwed shut.
Use a small screwdriver to open one of those "bays".
The BlueTooth adapter may become visible.
Or, if you open the "wrong" one, you'll see your computer's RAM memory.
SOURCE: Bluetooth not working
Make sure it is enabled on the laptop and on the os. If windows it will be in the control panel. and on the hardware it will likely be a function key
