Question about Bryant 462AJC021BA Air Conditioner
Is this a self contained unit or does it have an outside component, unit is in a 1997 mobil home
  • doneaux Jun 29, 2009
    thanks, any idea where one would find a schematic for a mh1aj036
  • doneaux Jun 30, 2009
    thanks.....
    President:
  • 2,692 Answers
Complete, through the wall . Self contained unit.
http://www.shopping.com/xPF-Bryant-462AJC021BA
Posted on Jun 29, 2009
  • Thomas F. Schneider Jun 29, 2009
    Sorry,I have no idea where to get the schematic,except through the dealer. It should be already on the unit under the cover.
I need to know if the Ruuduaka-042jaz 3.5 is good for a mobile home
The outside unit will work,but not the matching furnace!
you have to have a specific manufactured home furnace, because off Co
Nov 15, 2015 | Ruud UAKA042 Air Conditioner
Just wondering am being billed for antifreeze added to my mobile home apparantly job was done outside only and they didnt need inside is this possible?
If you're speaking of adding refrigerant gas to the compressor of your outside AC unit. Then no, that it was not necessary to enter your mobile home. However, most technicians would, to make sure the AC is cooling properly. Where you not at home when this occurred?
Thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
Where is the outside water tap turn-on/off under the trailer on a 1997 fleetwood doublewide?
On almost all mobile homes the main water supply will either be under the home and usually right underneath the water heater or behind a access panel in a wall close to the water heater or washer hookup. Thank you.
Jul 01, 2011 | Heating & Cooling
Check engine light comes on. Was told the purge valve soliniod may be sticking. Is there anyway to lubricate it?
It has been my experience that the purge solenoid assembly on most vehicles is a self contained unit and can only be replaced if problematic. Good luck
Oct 16, 2010 | 1997 Subaru Outback
Fridge is leaking water and ice builds up on bottom of freezer. it is now making noises all the time and i noticed the sides of the fridge getting really hot and it smells like like its over heating
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below/beneath the unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination.... Now the second part is the noise. The self defrost refrigerators contains a circulating fan to move air through the freezer and refrigerator compartments. The unit is located on the back wall half way up or near the top. You need to check that unit. If the sound is coming from outside/ back, you need to locate the component manually by observing the sound/ behavior. It might be the compressor, condenser fan or the defrost timer.If there is a rattling sound from the lower part, check for the loose component affixed with the unit and tighten it if required or balance the foot rests of the unit. And the last part, its feeling like getting over heated. That is a bit precise/detailed area to troubleshoot. The burning smell is due to any short component or any component current over loading... This could be from the main CU or other electrical parts. Check for above quoted possibilities... If the problem still persists the unit might needs to be inspection-ed by proper expert with precise tools....
This is all you need to know in order to trouble shoot the problem.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Samsung RS2630WW Side by Side Refrigerator
How do i add water to the air conditioner
You don't add water to the unit! It is self contain refrigerant in the coils and piping. Water is from condensation the is removed from the air and should drain towards the rear of the unit to the outside where it is not wanted! I hope this helps you to understand your unit somewhat.
Aug 10, 2010 | LG Electronic Window Air Conditioner
I want to connect 4 ton central ac to mobile home I have a license to connect ac units, but I have never done one in a mobile home. I have learned the hard way that things are done differently in homes...
does the mobile home have a modular duct system? i have converted a mobile home from a split system to a package unit and all i did was wire the package system outside 240v and 24v thermostat and we connected the existing ductwork that was in the house already to the package unit . not really sure about the code because we didnt have any requirements but it runs like a champ ..
Dec 08, 2009 | Heating & Cooling
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
Bryant 462AJC021BA Air Conditioner Logo
141 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
