Question about Fimco On Demand 12 Volt 1.0 Gpm Pump
Fimco 15 gal sprayer has lost prime
Pump has lost prime.it was working great but has since quit. it is two years old.HELP
    Problem Solver:
  • 3 Answers
There is an o-ring inside that is probably bad. I tore my pump apart and found it and repaired it. My sprayer was about two years old as well.
Posted on Jun 30, 2009
Pump sprayer has no suction
We have the exact same sprayer 2.1 GPM for our FIMCO and the engine runs but it will not suction. This happened once before last year and because it was under warranty they replaced it. Now it is happening again but FIMCO will not stand by this part because they don't "Warranty their warrenties.". What a bunch of ****! Stand by your products for pete's sake!!! If anyone has any solutions or ideas it would help us out a lot!
Apr 14, 2012 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No...
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Jun 25, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Jun 05, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
LAWN SPRAYER PUMP WILL NOT SUCTION
Disconnect the sprayer boom hose from Y splitter, and dd another Y splitter, then reconnect the boom hose to one side of the added splitter. Add a washing machine supply (female/female) to the other side of new Y. now attach garden hose to washing machine line and turn on the water faucet with pump running. This will charge and/or backwash the pump. Once pressure is achieved, turn on the boom and check for fluid movement, then turn the washer supply valve on Y to off, and disconnect. The pump should be primed and be cycling fluid from tank and back to tank. Ready to shift to boom for use. I leave the washer hose and assembly zip-tied onto sprayer for easy future priming, and pump wash between uses.
May 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco On Demand 12 Volt 1.0 Gpm Pump Logo
738 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
ray gallant
Are you a Fimco Garden Expert? Answer questions, earn points and help others
