GemSound XP-550, worked great for about 2 hours
GemSound XP-550, brand new, worked great for about 2 hours then blew a fuse. Put new fuse in, blew that. Wasssuupp?
  • 4,234 Answers
The outputs are probably blown. This should be under warranty. Return it for a replacement.
Dan
Posted on Jun 29, 2009
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Sep 28, 2009 | Olympus SP-550 UZ Digital Camera
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Gemsound XP 550 blown fuse
This is a standard amp design which should be a relatively simple repair. The output transistors are probably shorted. Check those first. Second, check the rectifier diodes in the power supply. Usually there are protection circuits that will prevent the fuse from blowing if the outputs are shorted.
Let me know your progress. I will attempt to get the service manual for this unit to get you more details.
Dan
Jun 29, 2009 | Audio Players & Recorders
Fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
May 03, 2009 | Garden
The compressor gets hot and trips the breaker
More than likely what happen was the internal overload in the compressor was tripped and didnt reset for 5 hrs and when it did it popped the breaker. The compressor was probably already shot. Sorry
Apr 29, 2009 | Amana AFD2535DES French Door Refrigerator
Gemsound EXA-3955 Right Channel Problem
you sure you didnt flip the bridge switch on the back? its the tiny little black switch under the bridge output plug, if you have it set to "bridged mode" any input sent into the right channel produces only a hum, only left channel input works.
Apr 04, 2008 | Audio Players & Recorders
"Protect"
El circuito amplificador de audio esta dañado o dañados si trae mas de uno.
Mar 30, 2008 | Sony STR-DE375 Receiver
P10002 blown?
needs repair bad fets or outputs
May 08, 2007 | Rockford Fosgate Punch P10002 2-Channel...
117 people viewed this question
 Grubhead
Grubhead
