I do not have a camera at this moment that i can use but i can tell you the unit is tilted and is lower on the out side. however it still not dripping towards the back for some reason it is not getting to the back of the unit its pouring out the front.
  • misszygjoyce Jun 29, 2009
    i have taken it out and sprayed it but did not use any cleaner i will try that thanks
  • 82 Answers
The unit probably needs taken out of the window and given a good cleaning. Slime and lint build up in the evaporator pan and on the evaporator surface itself and causes water to overflow the pan. Be very careful to cover electrical parts, controls, motor, etc while cleaning. Use a good strong household spray cleaner to wash condenser and evaporator and rinse out with a hose spray. Careful not too much pressure. Let dry good and replace.
Posted on Jun 29, 2009
Water dripping from Friedrich Air Conditioner CP05 model annoying downstairs neighbour. Is there a drain hose for this model? Other solution?
Window unit A/C units must be mounted level side-to-side and slightly tilted down to the outside coil The condensation (water) that forms on the cooling coil drips from the coil and collects in a metal tray. The slight tilt of the case allows the water to drain toward the condenser coil and fan. The outside fan blade tip is positioned very close to the condensation water catch pan and the water is picked up by the rotating fan blade and thrown onto the condenser coil where it evaporates and accomplishes two things. This keeps water from dripping on the ground and lowers the head pressure of the system to improve the efficiency of the unit.
Aug 01, 2018 | Heating & Cooling
Beater brush will not rotate
If you have not had this unit in for any previous service, and you are tilting it back to engage the brush with the swich on carpet mode, then I would likely suspect the switch assembly in the upper handle. The new switch and harness can be replaced but you will also need the switch knob as well. Otherwise you can get the entire upper handle. This unit has a history of the lower cable wiring harness to go bad (not an easy fix).you can tell if you tilt the vac in carpet mode and wiggle the exposed cable at the bottom rear of the vac, if it starts and stops the it is bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Freezer door opens each time we close refrigerator door
This is an easy one to fix - at the bottom of your unit you have 2 adjustable wheels you can turn to raise or lower the unit. What you need to do is turn those clockwise which will raise the front - what you want is to have it slightly tilted to the back. As a test you can open your door 45 degrees and leave it - it should be able to close on its own.
Sep 25, 2009 | Kenmore Refrigerators
Volvo penta 740 lower unit will not go down.
Kind of sounds like the trailer switch is in control. Many of these switches have lockouts and if you move the outdrive past the trip point the other solenoids are dead. Watch fingers. There may be a tilt switch on the water side of the transom in the pivot housing.
Jun 26, 2009 | Boating
Unit tilted. Lower on right side.
check the screw alignments on the base, if the wrong holes were used putting the base on it will be lop sided
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
MY V4000 ony runs when i tilt the while unit the left side has to be at least 3inches higher than the right if lowered it stops booting or after booting freezes when lowered until picked up again?
It's probably overheating. Raising the one side is giving it more ventilation. Try blow some canned air through the fan openings and clear the dust out. Also try to see if you can tell if the fan is running. You may have a bad internal fan
Mar 06, 2009 | Compaq Presario V4000 Notebook
Unbalanced fridge
you need to first remove the bottom kick plate. you will notice two 3/8 bolt heads on each side. These are to raise and lower the rollers in the front and rear of the unit. There are also 2 legs in the front that can screw in. These are usually lowered after the unit is installed to keep it from moving.
Jan 31, 2009 | Refrigerators
Picture is blurred and sound is perfect.
dont know if its the same model as mine but mine has a small sliding focus switch underneath the view finder if you tilt the viewfinder up you may find it it may look like the clip that locks the viewer down but it slides side to side .regards norman
Nov 22, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
