Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
I cant get the clock to hold the correct time . Every time i set the clock it goes back in time 2 hours after awhile
  • 2,509 Answers
Have you tried using the reset hole under (use pin) and setting again? Also after setting you have to press the mode button again to go back into normal mode.If that fails it's probably broken.
Posted on Aug 17, 2009
How do I set the time on the unit. I follow the instructions but get no where with them.
1. scroll to G.D. (gear development) screen with the right button. they call it the S/S button. 2. hold down right button on computer head for a few seconds, the clock should now appear. 3. now press the grey set button on the back, the hour should start flashing. 4. adjust to the correct hour with the right button, then press grey set button (on back) again. 5. the minutes should now be flashing, adjust to correct minute with right button. 6. press set button and this will finish set up. the clock will display the correct time. 7. press the right button, the clock will go back to G.D. screen. Each time you press the right button you can scroll through distance, time, and average speed. 8. To display clock while riding, press the right button to G.D. screen, now hold down right button and the clock will display.
Jun 27, 2011 | Campagnolo Ergobrain 10
How do i change the time on my '99 pontiac sunfire?
Setting the Clock for AM-FM Stereo
Press SET. Within five seconds, press and hold the SEEK down arrow until the correct hour appears on the display. Press and hold the SEEK up arrow until the correct minute appears on the display.
Setting the Clock for All Systems Except AM-FM Stereo
Press and hold HR until the correct hour appears. Press and hold MIN until the correct minute appears. There will be a two-second delay before the clock goes into time-set mode, and the colon on the display will blink while in this mode.
If this is helpful, pleas rate this answer well.
Aug 05, 2010 | 1999 Pontiac Sunfire
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
How to set clock in 2000 GMC JIMMY
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
Nov 13, 2009 | Car Audio & Video
How do I set the clock on a 1998 chevrolet cavalier? The book says to press 'set' but I don't have such a thing on my panel.
Hello. try this and see if this works
Use the following procedure in order to set the clock display:
  1. Press and hold the HR button until the correct hour appears.
  2. Press and hold the MIN button until the correct minute appears.
  3. There will be a 2 second delay before the clock goes into the time-set mode.
Oct 03, 2009 | 1998 Chevrolet Cavalier
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
Need to change the date and time
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press "Play/Stop" to exit
Setting the Clock at any time.
1 Press and hold "Clock" until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down
"Memo/Repeat" or "ANNC/SKIP" until the
correct day is announced. Then
release the button.
3 Press and release "Clock". The current
hour setting is announced.
4 To change the hour setting, hold down
"Memo/Repeat"or "ANNC/SKIP" until the
correct hour is announced. Then
release the button.
5 Press and release "CLOCK". The current
minutes setting is announced.
6 To change the minutes setting, hold
down "Memo/Repeat" or "ANNC/SKIP" until the
correct minutes setting is announced.
Then release the button.
7 Press and release "CLOCK". The new day
and time are announced.
To check the clock, press and release
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
and MN Buttons
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
313 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
