Question about Car Audio & Video
I currently have (2) 10W7 in a ported box in the trunk of my 2002 Grand Prix. I have one JL Audio 1000 watt mono amp supplying power to the two 10W?s. It?s very sweet but I miss the low rumble you can only get with 12?s. I would have had them put in to begin with but the box would have taken almost all the trunk space so I went with the 10?s. To solve my problem a technician suggested I go with 1 sealed box with 1 10W7 and a JL Audio 500 watt amp to power it and a (1) 12W7 ported box with a 1000 watt JL amp to power it. Not only would this not take up any more additional trunk space the sound will be incredible. I listen to smooth Jazz and really miss the low rumble I use to get with 12's but I have never even heard of a mixing a sealed and ported box combined like this with two different size drivers and two different size amps. Right now my box with the (2) 10W7?s are ported and it?s my understanding that this is the factory recommended type of box for these drivers. The technician says he guarantees I'll be happy but this is new territory for me. I really don?t care too much about the trunk space anymore so I?m leaning towards playing it safe and simply going with (2) 12W7?s in a ported box with (2) JL Audio 1000/1 V2 Mono amps. One for each driver. That being said this other option has me very curious. Of the two which do you think would deliver me more bass with good low rumbles but with quality sound. Muddy base is not an option. Any have you ever either built or listen to a mixed system as I described above. To me it sounds like I?m going to be hearing a tight bass over shadowed by a ported box with twice the amps. I have had some technicians recommend different equipment but I?m already sold on JL so I would tell you that in advance. Regards, Larry
  • tplayer Jul 02, 2009
    This covered everything I was concerend about.
    Thank you!
  • 15,935 Answers
Thanks for choosing FixYa Larry.
I am an independent Car Audio Shop and have been working in car audio since 1993.
It is very common for different sized speakers to be used in a SQ (Sound Quality) setup like you want.
What the tech is suggesting is fine - as long as the crossovers are set properly.
What you're aiming for is to use the 10" for MIDBASS. This is the frequency that is between Midrange and Bass - so it is aptly named.
When you have Only Door speakers for Highs and midrange... and 12" for sub bass frequencies - there is an entire range you are missing.
Midrange should be crossed over to play no lower than 120Hz (door speakers)
MidBass should be crossed over to play from 120Hz to 80 Hz (10" subwoofer - used as midbass)
SubBass should be crossed over to play 80Hz to 35Hz
The 10" being in a sealed enclosure will give you tight & accurate midbass (guitar, bass, drums etc.. ) and give you a good kick. The tradeoff with a sealed enclosure is low power handling. The 10W7 handles the 500W all day long!!
The 12W7 will handle 500-1000W all day, and will provide the power and air displacement for the booming bass below 80Hz (Bass, Drum, etc) so it seems your amplifiers are well matched.
I would suggest having the car RTA tuned after the install is complete to be sure your gains are properly set. You dont want one range overpowering another.
Go with the single 10 & 12 sub setup... you may even be able to modify your current enclosure if they are seperate chambers.
Using (2) 12w7s will not give you the SQ setup you are looking for - and you will be missing the midbass range that is so prevalent in Jazz music. It will be overpowering and inaccurate.
If you have additional questions or concerns - please use the "Continue With This Expert" option so we are connected directly in the future.
Thanks for using FixYa!!
Posted on Jun 29, 2009
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL 1000/1 Amplifier
mine did that. i cleand the battery wires and hook ups now it works fine.
Jul 24, 2007 | Jl Audio JL1000 / 1 Car Audio Amplifier
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
