Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Chamberlin door will not close
Only closes when holding the button down
  • 504 Answers
THE PROBLEM IS IN THE SAFETY EYES
EITHER ALIGNMENT - WIRING OR A BAD EYE
HOPE THIS HELPS
Posted on May 26, 2010
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have a chamberlin liftmaster 1/3 hp.. the chain is loose, it drags on the garage door as it goes up and down. I can only get the door to go down if I hold the button on the wall?? How do I fix this?
It sounds like a door sensor problem for one. If the main light flashes 10 times when you try to close the door the sensors are probably not pointed at one another. Tweak them a bit and check to make sure the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors. The chain can be adjusted at the trolley.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Sears craftsman garage door opener
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
288 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
