Question about Home
What tools do u need to remove a Jacuzzi toilet seat - the top of the bolts r smooth & can't use a screwdriver - do you need standard or metric sockets? PLEASE HELP - THANKS monroemkeith@hotmail.com
  • monroemkeith Jun 30, 2009
    Steel bolts
  • Ned C Cook
    Ned C Cook May 11, 2010
    Steel or brass bolts?
    Problem Solver:
  • 16 Answers
Try pliers
Posted on Jul 27, 2009
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
Replacing water pump
Just a standard metric socket set a 10mm wrench, flat screwdriver( to place between two of the bolt heads to hold pump pulley in place so you can loosen bolts) just loosen don't remove yet you will need all to use screwdriver on
Apr 20, 2014 | 1997 Buick LeSabre
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet seat slips
You will need to tighten the bolts holding the seat to the bowl. This video well help although the seat may not be the same as yours.
http://vodpod.com/watch/793915-tighten-toilet-seat-bolts
Mar 08, 2011 | Jacuzzi Home
Ibought a new Jacuzzi toilet that came with a seat it will not sit right on the base can't ajust it and everytime you shift your wieght it skips any help or should i bring the seat back to lowes?
Number one make sure it is installed as the instructions say, the seat bolts most be tight. If that is right then if you are shifting a lot of weight you may need a thicker more heavy duty seat.
Feb 25, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Need to order a replacement toilet seat for Model Jacuzzi Era toilet. We have looked at Lowe's and other home improvement stores and all the available elongated replacement toilet seats do not seem to be...
Try checking plumbing supply houses instead of home improvement stores. Im not sure where you are located. Here in MO. I use Harry Cooper Supply or Riback Supply or Southern Materials. A good supply house should be able to help you find what you are looking for. Hope this helps.
May 04, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
Missing bolt for toilet seat
A standard toilet seat bolt should be fine. There are some with a rubber boot that expands as tightened but you should be able to reach the nut by reaching into the tank and under the lip. The new nut & bolt should be plastic so they won't corrode.
Apr 19, 2010 | Eljer Toilet Onepiece Canterbury ...
How do you replace the seat on a kohler lowboy?
There are two bolts that are under cover at the back of the seat. feel underneath for the nuts-pop the caps on top w/ a screwdriver. make sure you purchase the correct profile seat Elongated or standard..
Jan 20, 2009 | Kohler - Toilet Seat - Moondance -...
Home Logo
77 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
