Question about Kenmore Washing Machines
No power The washer it looks like there is no power;however, when it gets connected there is a click which means it has electricity.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!
Posted on Sep 15, 2010
Why won't the hose connect to the washer?
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Oct 09, 2016 | Earthwise 1850 PSI Electric Pressure...
I'm getting an f 71 code on myKennmore elite smart wash steam care quiet pak 9 HE5T. What does that mean?
the F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit." from here. Hope this helps, good luck.
Apr 15, 2015 | Washing Machines
Water starts to spray from the bottom of my Bosch Aquatak 120i when i turn the water on. Is it still safe to use when this is happening
Electricity and water can be a hazard which could be life threatening, but you can operate electrical equipment in a wet environment if you are careful and follow safety precautions. Most import, make sure the electrical outlet you are using for the pressure washer has a working ground plug. Just because an outlet has three prongs does not mean the ground is working. You need to use an outlet tester which is inexpensive from a hardware store or use a multi meter to test the ground for conductivity to earth ground. Your power washer should have a working GFI (Ground fault interrupter), and you need to press the test button to make sure it is working. If your power washer does not have a GFI purchase one from a hardware store. I would also plug the power washer directly into the electrical outlet since an extension cord could have a bad ground connection and will cause the power washer to pull more current from the outlet. Make sure the power washer is raised of the ground so it will not sit in a pool of water. If you follow the safety precautions you should be safe but keep in mind water does not carry the electrical current, it is the impurities in the water which carry the current. Therefore, water could be more conductive depending on the impurity of water. However, it sounds like a loose connection in the power washer which could also be an o-ring or a washer is broken and it would b a good idea to have it fixed.
Apr 29, 2011 | Garden
My Kenmore HE2Plus Model 110.47532602 shows F28. Won't power off, door locked and add a garment light on. NOt sure if diagnostcs completes itself-CLEAN WASHER is result. Per manual, check acutators for...
it is for a serial communication error. usually means you have a problem with one or more of the control boards in the washer. hopefully your under and extended wtty with sears. after you get your problem fixed get a surge protector for your washer. its operated by several boards that act like a computer and noone in their rite mind would use a computer with out a surge protector.
Feb 19, 2011 | Kenmore HE2 Plus Front Load Washer
My washer did not finish it's load and was flashing pf what does that mean there is still a little water in bottom
PF code is for power failure.check electrical connection at wall and also make sure you dont have a bad breaker in the fuse box.If every thing there is ok check power connections inside washer
Mar 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
The dishwasher won't start
nine, when you said the buttons work, do you mean they can be depressed and you feel the clicking? Well if the unit lights up with the indicator light showing power is on then check the float assy it maybe stuck in the up postion and if no power check house breaker/fuse and if ok then the thermal fuse is open somewhere depending on your series of dish washer and generally req some electrical knowledge to follow the electrical ladder diagram ..... this is the only thing I would look for before calling the repairman...
Dec 01, 2009 | Maytag MDB7100AWB Dishwasher
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher power washer electric K3.97 gun has two springs can not find where one goes.
have a look on karcher web site
www.karcher.com
click on europe
then click in international
go to service then spare parts
put in k3.97 and have a look.
hope that will help
damian
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
