Question about Boating
Where do i put hydraulic fluid in a power trim boat motor
    Champion:
  • 207 Answers
What year make and model
Posted on Jun 30, 2009
Evinrude 40 hp power trim why does it not engage from shifter handel or on up down buttons on engine?
Hi. Uncertain if you own a runabout or a larger boat but this might help. Because you have tried both control positions for the trim adjust, I suspect the trouble lies with 1. power to hydraulic pump (or electric ratchet motor if so equipped)
2. frozen, corroded or stuck trim plates or transom mount swivel points.
3. Check for correct levels of hydraulic fluid in system or test for correct voltage to ratchet motor(s) if this is the system used. Use a jumper cable to directly power the motors or activators if low, or irregular voltage found. Test again.
4. Any obstruction or debris deposition at or near the working parts.
Finally, a local marine mechanic will tell you what is wrong and the cost to fix.
Hope this helps.
Aug 21, 2017 | Boating
Have evinrude 225 etec and the hydraulic tilt will not tilt motor all the way up
Hey Hunter,
First, make sure the manual release screw is seated tight.(port side of engine mount) ..Does the pump run and just not lift? Does the motor jump and jerk while you are trying to trim up? Can you lift the engine by hand while you are trimming? Have you filled the fluid reservoir with fluid? - There is a cap with a slot on the reservoir - MAKE SURE the engine if at full tilt - fill the reservoir.. you can use Dexron type III transmission fluid.... check these items and reply to me.
Jul 02, 2017 | Boating
How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
Oct 16, 2016 | Volvo Cars & Trucks
88 four winds horizon 180.boat Sat inside 3years
Try putting trim motor wires direct to battery,if trin works then solenoid is faulty if not then trim motor is faulty,give it a small tap with a piece of wood
Sep 06, 2014 | Boating
Evinrude power trim wiring
I think I would got back to that dealer with the boat in tow .
Jul 01, 2014 | Boating
Evinrude 1998 power trim doesn't go down when on plane?
take it back to dealer that installed .
My 1978 140 evinrude electric trim tilt motor working but wont lift or lower happend suddenly after it lifted.maybe the pump?
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
Jun 06, 2009 | Boating
How do I bleed and change the hydraulic trim fliud in my 75 hs Mariner outboard? I believe that I had an airlock, I opened the pit screws, and the motor was able to go back down. It appeared that there...
you need to find your drain- fill screw get trim oil with a pointed tip cut tip to fit tight fill oil with trim up once filled turn bleed screww and lower motor fast once down tight bleed screw fast use trim switch to raise motor and bleed again do this 2-3 times and u should remove all the air comment me back if you have any ?s
May 18, 2009 | Boating
Where do i put in hydraulic fluid in a johnson 225 boat motor
if its an outboard you will see a reservoir near the cylinder on back, be careful and set the shallow drive lever so the weight is off the hydros when you open it, there can be up to 3000psi if it has weight/pressure on it
once added you have to blead air bubbles, go up then down at least 10 times
also a boat parts store(phone book) may be able to help you
Jan 02, 2009 | Plumbing
Boating Logo
578 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
