Question about Kenwood DNX7100 Car Video Player
DNX-7100 My GPS in the unit cannot find sattelite. It stays in the acquiring mode indefinatley and then asks indoors or in another state. Still no luck.
  • espy1899 Nov 24, 2007
    Thanks I actually figured it out. It was the connection to the antenna. They grey plastic pieces that clip together with the metal inside. I guess the plug on the HU side had come apart so I could actually pull the plastic off of the metal causing it not to connect to the other side securely. I tested by putting it together without the plastic and it was good. I just put it together better.
  • puzzledgav Feb 17, 2008
    My dnx7100 cannot connect to satellite either. It just keeps saying acquiring satellites, but never moves on. I checked my connections, wiggled them around, checked the wire, tugged on things, anything I could think of, but nothing works. I bought this online, so I can ship it back for warranty repair, but I only just got it yesterday, and if I can fix it, I will be out of a radio completely until they fix it. HELP
Got the antenna plugged in to the head unit? It's the little 1" square black thing with the mini USB plug on it.
If you do have it plugged in then you may want to test the antenna by making sure it isn't being blocked by metal in your car. Just hold the antenna outside the car and see if you get reception then. If you do than you will have to relocate the antenna.
Posted on Nov 21, 2007
I have Kenwood DNX 7100. I plugged my car charger
how do i put my kenwood 7100 in discovery mode so i can pair to my phone?
Oct 15, 2009 | Kenwood DNX7100 Car Video Player
Unit won't Acquire Sattelites
the chip set in it is want to go to a servicing center to repair it.
Jul 19, 2009 | Garmin eTrex Legend C GPS by
Keeps Losing Sattelite Connection
Try making surte the battery is fully charged by AC charger, do not rely on DC plug to fully charge the unit. Also depending on age use and abuse ( starting car while connected to DC) replace the battery and you should be on your way again
Jun 29, 2009 | Garmin Nuvi 680 GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 Can not locate Sattelites
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 21, 2008 | Garmin Nuvi 660 GPS Receiver
Kenwood DNX 7100
Go to this website and download the free update software:
Oct 20, 2008 | GPS
Locating satellite
I have a streetpilot 330c so this may not help you.
After it fails to acquire satellites, my unit asks "Are you Indoors" and "Are you still in North Carolina". If you answer "NO" to "Are you still in STATE", rather than "Acquiring satellite", it will attempt to "Locate satellite" and that seems to do the trick for my unit...
Jun 13, 2008 | Garmin GPS
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Not acquire sattelites
place the GPS outside with a clear 360 degree view of sky or as much of the horizon as possible and leave it for a few hours it needs to download the almanac from all satellites before doing this
from the Acquiring Satellite page press menu and make sure that the topline of the menu reads "Use With GPS off" if it reads "Use With GPS on" (this means it will not find any SAT's ie for indoor use) press enter to turn the GPS Receiver on
Jan 01, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Kenwood DNX7100 Car Video Player Logo
158 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
