I have a control failure indicator on a goodman heat pump/ac. Nothing happens when I turn the thermostat on, the fan will not even come on when it is in the "on" mode. What does the control failure indication mean? The LED indicator is off completely, it is not flashing any codes whatsoever.
  • card92 Jun 29, 2009
    Thank you.
  • 583 Answers
Control failure means that the control board circuit is failed and is not able to commant any part of the unit to work.in that case the only thing that can be done is to replace the control circuit board. its a job to be done by a proper tech to fix the new board.the new board should cost approx 110 dollars.plust the technician service charge.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 29, 2009
Have GOODMAN AWB2405D UNIT and turned thermostad to heat and then when it got warmer, I turned back to ac/fan, but nothing is happening. Any tips would be appreicated.
i would say a thermostat issue. mine acts like that sometime havee had to pull front cover on stat and clean contact surfaces.
Feb 22, 2015 | Goodman Heating & Cooling
Why contactor on heat pump will not energize heat mode?
Heat pump and AC are basically working the same principle. When you turn on the heat pump is just like to turn on the AC. The main contactor will energize to turn on the compressor. The only difference is the 3 way valve, either switching to AC mode or heat mode. It is the most commom problem for heat pump. Check the thermostat wires for heat mode and defrost control.
Feb 05, 2015 | Heating & Cooling
Fan keeps running
the safety built in is when the sequencer goes bad it turns on the fan so it doesnt create a fire. replace sequencer. to make sure check amps if over 6 or7 amps sequencer is faulty
Jun 08, 2013 | Goodman Heating & Cooling
GOODMAN AIR HANDLER, FAN AND HEAT STRIP COME ONLINE WITHOUT DEMAND. WON'T TURN OFF BY TSTAT
the w wire off thermosta controls heat. eithe bad board or thermostat.
Feb 01, 2013 | Goodman Heating & Cooling
Fan does not turn off even after disconnecting
Are you referring to the fan on the external mechanism, or the internal air handling fan?
The external fan is not controlled by the internal thermostat. it is controlled by the thermos-witch of the compressor. The external fan may or may not run when the motor is operating. it depend totally on the temperature of teh compressor, and not the internal thermostat.
It the internal air handling fan is running continuously,it may be a a problem with the fan setting. check if the fan is set to 'ON' instead of 'AUTO', and correct it.
Incidentally the fan operation I described, is for modern, energy efficient heat systems. This is a energy saving design incorporated in all heating systems including automobile radiator fans.
Jan 31, 2010 | Goodman Heating & Cooling
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman: My Power Venter (aka Heat and Draft Inducer) won't start
The power ventor most likely needs to be replaced. But be advised. Goodman normally will not sell parts to anyone but a certified technician. I had to show my masters certificate to buy parts from their outlet. This is a part that has a high rate of failure.
Ray
Dec 01, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
