Question about Canon i850 InkJet Photo Printer
Will not print
Flashes orange 7 x and then green once. I tried turning off, and following the recommended procedure. I can get it to a solid green but then it says printer off line. I'm late for a meeting. HELP.
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
Posted on Feb 09, 2008
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
When i switch on the canon ip4300 printer orange light flashing 5 times
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
Feb 28, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i950 won't print
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
now is the most crucial information that has to be followed
Thanks And Regards
May 12, 2009 | Canon i950 InkJet Photo Printer
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
S9000 printer will not print.
Hi
Try this see if work for you.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Jan 13, 2009 | Canon i950 InkJet Photo Printer
CANON PIXMA MP150
Error E/2/7 Solution=waste ink basket
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Sep 03, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon i850 InkJet Photo Printer Logo
127 people viewed this question
old marine
old marine
