Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Courtesy light not going off
THE OVERHEAD DOOR IS RAYNOR
    President:
  • 3,197 Answers
This is usually caused by electrical storms. Electrical surges seem to get to the small relays that control the light and fry them.
Posted on Jun 30, 2009
My garage door won't close makes Moab sounds. Needs a manual of raynors model pilot
Hello, Melvin -
If you have not yet thought to contact Raynor Garage Doors directly and ask for help, I suggest you do so. This is the link to the Raynor Garage Door Contact Us web page:
.http://www.raynor.com/contact.cfm
You will find the Consumer Inquires phone number there.
I have no idea what "Moab sounds" are.
Best wishes.
Apr 27, 2018 | Building Materials
I have a 2007 Buick Lucerne and the front reading lamps won't turn off.
Overhead Console Lamp and Roof Rail Courtesy/Reading Lamps
The courtesy/reading lamp is a duel purpose lamp that can be illuminated two different ways. First, the lamp can be turned ON during courtesy lamp operation as described above. Second, the lamps can be turned ON individually for reading lamp operation by the lamp switch. The BCM supplies battery voltage from the INT LAMPS fuse through the inadvertent power courtesy lamps circuit to the courtesy/reading lamps for reading lamp operation only. Ground for the courtesy lamp module or the roof/rail reading lamps is provided at G402
Courtesy Lamps
When either one of the front doors is opened, ground is applied through the door latch door open switch and the door open switch signal circuit to the door module indicting the door open position. In response to this signal, the door module sends a GMLAN serial data message to the BCM of the door open position. Or, when either one of the rear doors is opened, ground is applied through the door latch door open switch and the rear door open switch signal circuit to the BCM is indicating the rear door open position. Once a door open message or signal received, the BCM will then apply battery voltage from the CTSY/RF TRN fuse through the courtesy lamp supply voltage circuits illuminating the lamps listed below:
• Overhead console lamp
• Roof rail courtesy lamps
• Footwell courtesy lamps The BCM receives battery voltage from the INT LAMPS fuse in order to supply power to the inadvertent courtesy lamps. Inadvertent power courtesy lamp feature provides a similar function for the interior lamps as a retained accessory power feature. The BCM will energize the courtesy lamps supply voltage circuit when the BCM is in the active state (awake). When the inadvertent power courtesy lamps supply voltage circuit is energized, it supplies voltage to all the interior lights listed below. The BCM will continue to supply voltage to the interior lamps after the ignition is turned OFF so that the interior lamps may be operated.
• Overhead Console Reading Lamps
• Roof Rail Reading Lamps
• Vanity Mirror Lamps
• I/P Compartment Lamp
• Rear Compartment Courtesy Lamp
In the event that any of these lamps were to remain illuminated for a period of more than 20 minutes with the ignition switch in the OFF position and no BCM input activity, the BCM will deactivate the inadvertent power supply voltage circuit to prevent a total battery discharge condition. The BCM receives battery voltage from the CTSY/RF TRN fuse in order to supply power to the courtesy lamps. The BCM applies this voltage to the courtesy lamps through the courtesy lamp supply voltage circuits. When any door is opened, the door open switch contacts close and the BCM receives a door-open signal. If the BCM receives a door lock or unlock signal, the BCM will activate the courtesy lamp supply voltage circuit, providing battery voltage to the dome lamps and the left and right footwell courtesy lamps. The courtesy lamps can be manually activated by placing the interior lamp switch in the DOME position. For more detailed information concerning courtesy lamp operation refer to Interior Lighting Systems Description and Operation.
Jan 16, 2017 | Buick Cars & Trucks
2002 ford explorer xlt overhead lights not turning off. I have replaced the 2 front door ajar switches and everything worked. However, I pulled up and parked and the overhead lights would not go off.
Which overhead lights ? Just the dome lamps . If there is no door ajar light lit on the dash . There could be a problem with the G.E.M - Generic Electronic Module . You should have it check for DTC'S - diagnostic trouble codes . Need a special scan tool ,a OBD2 code reader won't do it.
  • The courtesy lamps stay on continuously
  • Circuitry.
  • GEM/CTM.
  • Ignition switch.
  • Interior lamp relay.
  • Dimmer module.
  • Door ajar switch.
  • DTC B1322.
  • DTC B1330.
  • DTC B1334.
  • DTC B1338.
  • DTC B1371.
  • DTC B1574.
  • DTC B1610.
  • GO to Pinpoint Test D .
You best bet mite be to have a Qualified repair shop diagnose this .
Nov 09, 2016 | 2002 Ford Explorer
2009 dts inside lights stay on
this could be a door switch problem or a BCM problem. access the BCM for codes and data this will help. check to make sure the headlight switch for the interior lights is in the off position.
Mar 20, 2015 | 2009 Cadillac DTS
Raynor garage door motor won't run and won't open the door. It is not sending power to the system despite being plugged in to a working outlet.
More than likely, the transformer in the opener is fried. You need to verify 110V power coming into the transformer, and that there is 24V AC power coning out of the transformer
Oct 03, 2014 | Raynor Garage Doors 4050047 Raynor PEC-R4...
What is a ctsy fuse go to
Courtesy lights mostly, door mounted, under dash mounted, overhead dome lights, lighted vanity mirrors, sometimes the trunk light or underhood light (if so equipped) are connected to the courtesy fuse.
Jul 31, 2014 | 1996-2005 Chevy Astro Van Carpet Front...
Interior courtesy light
Page 116 and 117 of the manual explain that there's a two-position slide switch on the map light, DOOR and OFF. The back light has three positions, ON, Door Activated, and OFF.
Pages 116 and 117:
http://techinfo.honda.com/rjanisis/pubs/om/ACC080/ACC0808OM.pdf
Dec 12, 2013 | Honda Cars & Trucks
Courtesy light trigger
If the interior lights won't come on with either door open, you might have a blown fuse or the overhead light may be switched off.
Parts book shows a door jamb switch for each door.
Jul 08, 2012 | 1990 Pontiac Sunbird
My 2003 cad De Ville has a problem with the courtesy light, When I unlock or open the door the courtesy lights do not come on. I have4 checked the relay and fuses and fins all O K. I suspect the rear...
Did you check that the overhead light is set to "door" instead of "on" or "off". I know it's a simple solution but you didn't mention having checked it.
Mar 03, 2011 | 2003 Cadillac Deville
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
310 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
