Question about Lexmark X5470 All-In-One InkJet Printer
NEED SETUP DISC FOR PRINTER
NEED TO ORDER REPLACEMENT SETUP DISC
  • 27 Answers
Here is the link to the driver download: http://downloads.lexmark.com/perl/downloads/downloads.cgi
you pick XP or Vista but if you want the CD's you can do a chat with them from the site, I had a different printer and I lost the CD and they sent me a replacement for free!
Posted on Jun 29, 2009
Just install new hard drive in my laptop....old one frozen. i have an activation key for windows 8.1 pro. how do i install new operating system?
Boot from your installation disc. Insert the installation disc into your optical; drive, and reboot your computer. Normally a computer boots from the hard drive first, so you will need to adjust some settings in your BIOS in order to boot from the disc drive. You can enter the BIOS by hitting the designated Setup key during the boot process. The key will be displayed on the same screen as your manufacturer's logo.
  • Common Setup keys include F2, F10, F12, and Del/Delete.
  • Once you are in the Setup menu, navigate to the Boot section. Set your DVD/CD drive as the first boot device. If you are installing from a USB drive, make sure that the drive is inserted and then select it as the first boot device.
  • Once you've selected the correct drive, save your changes and exit Setup. Your computer will reboot.
Oct 31, 2016 | Computers & Internet
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
What can I do to fix this problem, my gr 500 is telling me to reboot and select proper device or insert boot media in selected boot device
You need to go into your Bios or System Setup and change the boot order or boot sequence. It sounds like you might be trying to boot from a Network or Lan. It could be that you are trying to boot from the CD drive but instead of having a operating system disc in the drive you might have a movie or music cd in the drive.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Gateway 500GR PC Desktop
My Sony Vaio laptop had a malfunction. Someone I knew offered to reformat it. But afterwards, he realized I didn't have a recovery disc. He then installed Ubuntu system just so I can have access to the...
You need to change the boot order in the bios / cmos settings. When you start the computer pay close attention to the display. Usually you'll see something along the lines of Press F2 or F10 to enter setup. The "setup" page is what you're after.
Once there you'll need to change the device boot order. Just move through the various menus and you will for sure find what I'm talking about. Just make sure the first boot device is set to "cd / dvd / optical" Different cmos menus call it different names, but you'll figure it out don't worry ;)
Once it's set correctly it's just a matter of booting to the cd and following the prompts.
Hope this info helps!
Oct 18, 2010 | Computers & Internet
Acer Aspire85 wont boot anything
You need to get into Bios Setup when the pc first starts.
I am not sure but I think the F2 key lets you into Bios Setup
The primary boot device needs to be the Cdrom drive.
The starting order for the pc needs to be set to
1st Cdrom
2nd HDD
You should then be able to install Vista.
Jul 01, 2009 | Computers & Internet
Rear wheel setup vx 125 07
c34b1f2.jpg so is it ok and do u understand
Jun 13, 2009 | 2005 Gilera Runner VX 125
Operating system not found
Oops---virus may have destroyed the boot sector on your hard disk. Is there a CD in the optical drive, or a floppy in the floppy drive?? If so, remove before booting. If that's not the issue, you need to reinstall the operating system.
As far as original discs---perhaps you can get replacements from Sony if they still support the laptop?
Mar 26, 2009 | Computers & Internet
I lost my setup CD-ROM. I cannot setup my computer without my CD-ROM
GO TO THE WEBSITE OF THE BRAND OF YOUR COMPUTER AND MOST TIME YOU SHOULD BE ABLE TO DOWNLOAD A SETUP DISC OR ORDER ONE AT LEAST. AT THE WORST YOU COULD GET AN OVERNIGHT DELIVERY ON A DISC AND BE BACK IN BUSINESS IN 24-36 HRS. THEN, MAKE COPIES OF THE DISC! BUT, MOST BRANDS WILL HAVE SETUP DISCS AVAILABLE. TRY THEIR WEBSITES. GOOD LUCK.
Oct 31, 2008 | Office Equipment & Supplies
A70 recover disc in A35 Laptop? (Toshiba Satellite)
Recovery disks are model-specific, mainly because they have different devices and drivers. Setup drivers are downloadable, and copied to a CD at an Internet cafe.
May 16, 2008 | Toshiba Satellite A35-S159 Notebook
Lexmark X5470 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
