Question about Haier HRF10 Top Freezer Refrigerator
Haier HRF 10 Moaning sound coming from Condenser
Can any of the masters here help me how to oil the condenser fan or even to replace the condenser fan.
Thank you very much for your time
5 Suggested Answers
  • 219 Answers
SOURCE: Condenser fan made a lot of noise then stopped.frig warm.
take back metal panel off u will see it then
Posted on Mar 19, 2009
  • 2418 Answers
SOURCE: Haier HRF10 Moaning sound coming from Condenser fan.
It is the fan, Its time for a new one or try to oil her.
Posted on Jun 29, 2009
  • 1218 Answers
SOURCE: Condenser fan always runs so freezer won't
Good day,
The fan motor runs when the thermostat asks it to.
If the machine is not at the proper temperature, the fan will run 24/7.
You have a cooling problem with the machine.
here are some areas to check.
1. The fan motor in the freezer compartment. It is behind the rear panel. You should be able to hear it running when you open the freezer door.
2. The defrost system has failed. Once again, open the freezer door, if you see frost built up on the rear panel, Either, the defrost timer, defrost thermostat, or main heater has failed.
3. The compressor is bad, or the start components mounted on the side of the compressor have failed.
4. Refrigerent has leaked out, or the system has an internal restriction.
The last 2 items are best left to a trained repair technician.
Posted on Dec 05, 2009
nnesmith
  • 162 Answers
SOURCE: I come home and water is on the floor due to my
check that compressor is running. if your hearing a hum and then click you probably have a faulty compressor relay. most times you can pull it off and shake it and you will hear little bits rattle, well it should actually make no sound. but it could still be bad if compressor fails to run. compressor may or may not be warm.
Posted on Jan 21, 2010
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
Where is the drain hole on my haier air conditioner located
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
Jun 05, 2011 | Haier Heating & Cooling
Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Mar 02, 2010 | Heating & Cooling
Haier water dispenser WDQT015 cold water isn't cold
It's not condenser it is the compressor.
You may have a bad capicator or relay.
Try putting a HARD START KIT on the compressor and it should be fine
Dec 11, 2017 | Haier WDQS055
Air cond cutting on high pressure
Sounds like there is insufficient cooling through the condenser, either airflow or the refrigerant may be restricted through the condenser due to clogging of refrigernat oil / contaminates. Try spraying cool water from a garden hose over the condenser while the A/C is engaged and monitorthe pressures, if they drop you know there is a problem at the condenser. If you're confident about the operation of the fans / airflow then replace the condenser.
Aug 21, 2009 | 2003 Toyota ECHO
Haier HRF10 what would happen to the fridge without condenser
it could but the possibility is low but you willl ruin the ref doing that
Jun 29, 2009 | Haier HRF10 Top Freezer Refrigerator
Jun 28, 2009 | Haier HRF10 Top Freezer Refrigerator
Rudd 2 ton 10 S
The small copper line should not be really hot its supposed to be carrying liquid refrigerant which has already had the heat "pressed" out of it by the compressor and carried of by the air flowing over the condenser coil. This could indicate a few things; that your unit is overcharged, you have a mismatched evaporator coil and condenser, an ineffective condenser fan motor or a clogged condenser coil and as a result your compressor is shutting of due to an overload condition from the building heat and back pressure between the compressor outlet and the evaporator inlet.
First make sure your condenser is clean and that adequate air is flowing over the fins of the condenser coil. Then be sure your equipment is a matched system. A indication that your condenser fan motor is not at speed is slow starting a humming sound and excessive heat. In my experience this complaint is generally the result of a bad condenser fan motor that over heats and shuts of after a short period and the build up of heat in the liquid refrigerant line of course trips the compressor overload circuit- which by the way usually takes hours to reset. I hope you've already resolved this, but in case you haven't......
Aug 01, 2008 | Ruud Matching Split Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Haier HRF10 Top Freezer Refrigerator Logo
53 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
