Question about Danby Portable Air Conditioner
Only working if I use the remote
All the buttons on the console are not working or not working proprely. The 'power' button is changing the mode (as of the 'mode' button) and the button that controls the ventilation (high or low) is simply not working. Everything works just fine if I use the remote. I think the warranty expired already, any clue of what I can do?
Thanks
There is no power even when the power cors is plugged into the power outlet
Posted on Jul 31, 2009
My manual does not tell me how to turn off demo mode on my console and I need to turn it off Model #NordicTrack x22i treadmill incline
  • roperly connected to the NordicTrack and plugged fully into a grounded electrical outlet if the machine does not turn on. If the unit is plugged in correctly, look at the reset switch, located on the frame near the power cord. If the switch is flipped open, wait five minutes then push the switch back in.
  • Remove the key from the console, wait a minute and reinsert the key back into the console if the buttons on the console are not functioning properly. If the console stays on when the key is taken out of the console, the device is likely still in "Demo" mode. Hold down the "Stop" button for a few seconds to turn off the "Demo" mode and restart the unit.
  • Turn the machine off and unplug the machine if the console display is not working correctly. Wait a few minutes and plug the machine back into the electrical supply and turn on. The console should now operate correctly.
  • Hold down the "Stop" and "Speed" buttons at the same time if the incline is not changing as desired. Insert the key into the console while holding down the buttons and then release the buttons. Press the "Stop" button and the arrows to increase or decrease the incline. This will cause the incline to recalibrate. Remove the key from the console unit.
Sponsored Links
May 03, 2017 | Exercise & Fitness
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
My power button is not working means my laptop power button is not working proprely i mean its not Restarting
what kind of problem thoes you mean you press power button and your system shuts down in place of restarting
Jan 04, 2011 | Acer Computers & Internet
Yellow light on wii
It's just the way the wii works. Hold the power button for about 5 seconds and the power button will go red and turn off instead of going yellow and going into standby mode.
www.wiihdmods.com
May 07, 2010 | Nintendo Wii Console
Hard disc currupted for ps3
Thanks for using Fixya.
To solve your problem, you need to enter the Diagnostic mode and rebuild the drive's structure.
Diagnostic Mode:
1)Turn off system
2)Hold power button through 1 startup and shutdown cycle...
3)Release button...
4)Hold power button until you hear two-simultaneous beeps, then release
5)Connect controller with USB cable and push PS button
6)Pick diagnostic option you desire...
7)Allow changes to be implemented...
8)Restart fixed console...
If this doesn't solve your , call Sony and they will replace it for you.
Good Luck and have a nice day
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3
it will take awhile but just keep switching the back power button on and old the power button until it comes on just keep repeting
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My ps3 wont display the screen but when i use the service menu it works
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 works but i cant get it to show on tv
try video reset
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
I turn on my Ps3 and its working and turning on but nothing shows up on the tv screen. All the cables are working so what do i do?
try video reset
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Danby Portable Air Conditioner Logo
220 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
